Junglejoe
- Mar 9, 2016
- Reaction score
- 66
- Location
- Columbia Missouri
- Make / Model
- Ford
- Engine Size
- 6.0
- Automatic
Well.. what I didn't know and didn't see anyone else talk.about it is the driver side motor mount has to come off to get the "spacer" from under the motor mount off. You have to take the whole freaking drivers side suspension apart to get the coil spring out to get to the 19mm nut that holds the motor mount on.. I played it safe and used a coil spring compressor you can get anywhere ,even rent it from autozone.
