- Jan 28, 2017
- Reaction score
- 44
- Location
- Leicester, NC
- Make / Model
- Ford
- Engine Type
- V8
- Engine Size
- 302
- 2WD / 4WD
- 2WD
- Tire Size
- 205/60R15 & 225/60R15
I have an '87 Ranger that came factory without a radio. It looks like the block off was part of the plastic dash trim. The last owner cut it out and put in a cheap radio and put on an antenna that's leaking rain water into the floor because of the wire rounting and no seal where it goes into the cab. The antenna base was caked in white house caulking and they ruined both doors and door panels putting in speakers that are so big the window cranks smack into them. The dash doesn't have speaker grills just solid plates where speakers would go. I want to put it back the way it came. I have a pair of door panels. Does anyone have a picture of the dash on a radio delete Ranger or Bronco II? Also the antenna hole looks stock. Maybe it had a base and a plastic cap instead of a mast? The truck has zero options that I can tell and that's the way I like it. I already have an '86 with a nice stereo and PS, PB. I want the '87 to look the way it came. Any pictures of the stock radio delete setup would be greatly appreciated. Pictures of the dash, pictures of the cowl, anything.
