Found! Wiring harness
smudvapor
152
Youngstown, Ohio
"Lets stop thinking in terms of limitations and start thinking in terms of possibilities."
Looking for an under hood wiring harness for an 88 2.9 M/T RWD Ranger. I need the complete harness for everything. Thanks.
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
Bird76Mojo
1,265
IL
You're welcome to drive to my place in central Illinois and pull one yourself from my 89 single cab 2.9 5spd twinstick 4x4
It's gonna go to the scrapyard sooner or later, but I'm not gonna pull any parts for anyone.
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
I would but that is a bit of a drive for me, thanks.
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
89 is different then the 88....looks like to figured that out.
not sure if i have one or not. non egr correct?
smudvapor
152
Youngstown, Ohio
smudvapor
152
Youngstown, Ohio
