Windshield washer plumbing?
spottedsquirl
I have a 94 ranger. On the washer hose, there is a T fitting that splits off between the washer nozzles and there is a hose leading from that T fitting and goes through the fire wall. Where does that goes go to and what function does it serve? Thanks.
8,290
Someone is pulling your leg or your truck's leg :)
Washer Fluid container is with Overflow tank in engine bay.
Hose runs from Washer Fluid reservoir to the "T" that feeds the two nozzles
Nothing goes thru firewall
Wiring for washer fluid pump is part of main wiring harness so does go thru the firewall, with other wires
spottedsquirl
I'm not pullin any legs lol. I'll send pics. I'm scratchin my head on this one. That is the washer line with the T fitting and hose going through the fire wall.
8,290
I see it, maybe Ford was trying to preheat the fluid by running it thru the heater core box.
It needs to come out somewhere to connect to washer reservoir
ericbphoto
Overlander in development
16,335
Wellford, SC
3.0L
6"
I'll try to remember to trace mine tomorrow and see where it goes. Should be same from 93 to 94.
Eric B
ericbphoto
16,335
Wellford, SC
3.0L
6"
I just looked at mine. That hose is not going through the firewall. It is going into a void space (cowl area?) Where it the connects to the washer nozzle. The driver side line does the same.
Eric B
Kirby N.
March Truck of The Month
