Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Notices
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 04-03-2016, 08:33 PM   #1
it-broke-again
Junior Member
it-broke-again's Avatar
Vehicle Make: Ford
Vehicle Model: 1995 Ranger XLT 4.0L 4x4 5 speed 2002 Ranger XLT 4.0L 4x4 auto
it-broke-again is on a distinguished road
Default i replaced the alternator and its still not charging
I have a 2002 ford ranger 4.0l 4x4 auto trans and it ran great until the other day when the battery light came on and later it would not start. I tested it with a voltage meter after I jump started it with my car and the voltage was bouncing between 11v and 15.8v. so I figured the voltage regulator in the alternator had went bad and bought another alternator to replace it only to find out that now its not charging at all. I took the replacement back and swapped it as if defective and still got the same results. I have a full 12 v running to the alternator post at all times, the yellow/white wire running to the regulator has a full 12v at all times, the white/black wire I tested for resistance between the connections and got none but the light green/red wire is only getting like 1.4v is this normal? and if so can someone please tell me what I'm missing here. I'm at a loss and don't want to have to dump a whole bunch of money into a shop because its not the best looking truck to say the least
it-broke-again is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 04-04-2016, 04:18 PM   #2
Raser13
Junior Member
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Everything! It's my daily.
My credo: I love it when a plan comes together
Raser13 is on a distinguished road
Default
If it's like older fords the light or gauge was integral to the charging system. If your bulb blew or the gauge went your alt would stop charging. One of the dumbest things I've ever seen. So if your gauge cluster light blew after it came on that may be it. If not idk.
Raser13 is offline   Reply With Quote
Old 04-04-2016, 04:28 PM   #3
it-broke-again
Junior Member
Vehicle Make: Ford
Default
I'll have to check the bulb the batt light stopped workng after the old alternator died
Sent from my XT1028 using Tapatalk
Old 04-04-2016, 04:57 PM   #4
RonD
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
It will be the fuse, not the bulb, look at your other thread about this.
The circuit has a resistor inline so if bulb does burn out alternator will still work.
RonD is offline   Reply With Quote
Old 04-04-2016, 05:05 PM   #5
it-broke-again
Junior Member
Vehicle Make: Ford
Default
Well my fuse tests and looks good in the fuse box and if it is a fuseable link in the wire where can I find it or would it just be easier to restring a new wire
Old 04-04-2016, 05:07 PM   #6
it-broke-again
Junior Member
Vehicle Make: Ford
Default
Is it also possible that the resistor has failed causing there to be no connection if the bulb burnt
Old 04-04-2016, 07:14 PM   #7
RonD
Vehicle Year: 1994
Vehicle Make: Ford
Default
That would be a long shot, not impossible, just not likely.
read here, your other post: http://www.therangerstation.com/foru...d.php?t=166634
test wires as stated
And check the in cab fuse panel for #11 7.5amp, thats the battery light fuse on a 2002, I checked
Fuses are test with an OHM meter, not an eyeball, women are tested with an eyeball, there are other differences as well....fuses and women that is
Old 04-04-2016, 07:30 PM   #8
it-broke-again
Junior Member
Vehicle Make: Ford
Default
I have tested the fuse with a ohm meter three times now and it is good but no light comes on fit the battery light, I have no charge from alternator, and still low voltage at the green/red wire
Old 04-04-2016, 07:49 PM   #9
RonD
Vehicle Year: 1994
Vehicle Make: Ford
Default
May be thats the wrong fuse, with fuse out, key on, is the low voltage on the green wire gone?
It should be if thats the right fuse.
It will be a 7.5amp fuse
Alternator is OFF if there is not 12volts on the green wire
An alternator will run down the battery if left ON, so it needs to have an ON/OFF switch, thats the green wire
The Battery light is used because if alternator is ON but not spinning(generating voltage) then it is a Ground, with 12volts from the fuse and a Ground at the alternator the Battery Light Bulb is ON.
When alternator spins, engine running, the green wire now has voltage from the alternator, same voltage as at the fuse, so with no Ground the Battery Light goes off.
If alternator quits generating power, broken, then green wire is now a Ground again so Battery Light comes ON
Old 04-04-2016, 07:51 PM   #10
Willcastle
Vehicle Year: 1992
Vehicle Make: Ford
Willcastle is on a distinguished road
Default
The alternator will not work properly with the batt. Light not operational
Willcastle is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
