93 4.0 getting power to only drivers side injectors
Kasten007
My 93 ranger only is getting power to 3 injectors pretty much making it a 3 cylinder, what is causing this? The injectors are good but they just aren't getting power.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Welcome to TRS :)
The Red wire on all 6 injectors should show 12volts(battery voltage) with key on.
The Red wire is just daisy chained from one injector to the next on each bank.
So you have a broken Red wire if 3 injectors show "no power".
If you are using Noid lights, then "no power" could mean something else.
The Computer Grounds the injectors to open them, so the "other colored" wire at each injector won't show Ground except when engine is running and computer is pulsing the Ground to open the injectors.
In '93 a V6 will be Batch Fire injection, so 3 injectors will share the same "other colored" wire that goes back to computer.
Example: 3 injectors may have a Tan wire and the other 3 a White wire
So only 2 "injector" wires are needed back to the computer, but if one of these breaks..........it would effect 3 injectors.
Staff online
Today's birthdays
Shran
April Truck of The Month
