T-Case Shifter ?
np24
Derby, Ct
I have a m5od with a bw1350. I bought a shifter from someone on here that was for a bw1354, a straight bar rather that a bent bar. I traded that one for one that was supposed to be for a bw1350. it bolts up, but the bar is about 1/2" too short. In 4hi, it lines up, but as soon as you push it forward for 2hi, it pops off of the linkage on the t-case.
Also, if I get it lined up and pull it all the way back, 4low position, the shifter sits just a lil back from neutral, not in the 4low spot.
Does anyone know what this shifter could be off of?
Thanks
Nick
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Be aware that the short arm that's on the t-case also comes in different lengths.
It's possible a longer one will fix your problem.
The thing is that there are over a dozen different shifter setups for the 13-50
AD
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
1354 long bars are straight. what's bent is the short arm that bolts to the shift bolt on the trans. 1350's i've seen have a bent long bar, and a straight short bar that bolts to the shift bolt.
that's about all i can give ya. allan knows his sh!t. lol.
