Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Ford Bronco II's
Notices
Ford Bronco II's Be sure to check out the Bronco II Corral!
Reply
Thread Tools Display Modes
Old 08-27-2008, 10:29 AM   #1
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: BroncoIV
I use this vehicle for: DD/Wheeler
CopyKat is on a distinguished road
Default List of B2 Options that never made it to production and some that did.
This is a rumor list.
1. Pop out Side windows-There is doccumentation that says there were. Owners manual discusses how to remove and store them.
2. Rear bucket seats-There are reports that they are out there. No pictures to back it.
3. 4.0L B2 in late 1990-No proof that they exist. If Ford made Prototypes then they would never have been sold, and likey to have been dismantled. 1991 was the intro of the Explorer. Someone that started the rumor likley saw an Explorer Sport 2 door and thought it was a new B2.
4. 8.8 rear axle.- Rumor and no proof of existance.
5. D35 front axle-*Confirmed*. Nearly all 1990 models will have a D35 axle. 3.73 ratio is a guarantee.
6. M5OD 5 speed trans.-*Confirmed* Most if not all 1990 models will have this as a manual trans. 1989 saw the last of the FM146's.
7. Real 2wd trans without dummy case in 2wd models-Yes and no. later model ones are rumored to have a ranger 2wd trans. AllanD would be able to confirm this. (I do confirm this AllanD)
All I can think of at the moment.
CopyKat is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-27-2008, 10:33 AM   #2
engdept
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Daily Driver
engdept is on a distinguished road
Default
Maurice and I looked at a '90 2wd Bronco II that had a true 2wd transmission in it from the factory. I was going to buy it until we saw that; if I got a 2wd, I wanted to be able to easily convert to 4wd.
Rear buckets would be NICE!
engdept is offline   Reply With Quote
Old 08-27-2008, 10:58 AM   #3
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
Quote:
In my 1990 BII User Manual, it references the 4.0 as an 'Optional' motor...I don't think they exist tho...
__________________
89-92 Rangers are best. Fight me.
1989 Ranger build - 4.0 swap, 7.5, Dana 35, 4.56 gearing, Lockers, 5" lift, Electric power steering
1976 Fiat Abarth 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Old 08-27-2008, 11:05 AM   #4
WhiteBroncoII2WD
WhiteBroncoII2WD's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
WhiteBroncoII2WD is on a distinguished road
Default
Quote:
A lot of the information for the engine section in the Owner's manual is shared with the engine section in the Ranger's Owner's manual.
WhiteBroncoII2WD is offline   Reply With Quote
Old 08-27-2008, 11:11 AM   #5
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Default
Quote:
Yeah, I guess that makes sense...but it's still in the BII manual, someone must have screwed up.
__________________
1990 BII-R.I.P.
Old 08-27-2008, 11:15 AM   #6
Boggin
Boggin's Avatar
Vehicle Model: 89 bronco ii
I use this vehicle for: going inappropriate places
Boggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to behold
Send a message via AIM to Boggin Send a message via MSN to Boggin
Default
hey, doen some researching and found this
http://broncoii.org/techpages/history/index.html
__________________
05 F250 - 6.0, 6 speed, deleted by RCD, SCT tuned, blue spring, sinister coolant filter, dummy plugs/stand pipes, Atlas 80 ficm, afe intake, 4" turbo back straight to 5" mitre cuts, 6" lift with rear air bags, 35" pro comps
04 Ranger 4.0 4x4 - stock
02 Duramax - afe intake, Super chip, straight pipe
93 W 250 12v cummins - stage 5 fuel pin
Lots of past rbv's
"Dont know how to drive automatic"- Chance. RIP Buddy.
Boggin is offline   Reply With Quote
Old 08-27-2008, 11:19 AM   #7
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
If you thought engineers were bad, the guys that put the owners manuals together know less of the vehicle than a 2 year old would.
The engine chapter was likely borrowed from the ranger manual. The haynes manual shows a 4.0L ranger/bII engine electrical schematic, but we all know it's for the Ranger.
FWIW if you can find a 1990 4.0L in a Ranger the 4.0L swap into a 1990 B2 will be a True Plug and Play. A 1991 4.oL is close but there are a couple of plugs they swapped around.
Old 08-27-2008, 11:22 AM   #8
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Yup that's the brochure add. There is another page to it however, I believe I've seen it. I also remember a site dedicated to the chapters in the owners manual about the pop out windows.
Old 08-27-2008, 11:25 AM   #9
WhiteBroncoII2WD
Vehicle Year: 1989
Vehicle Make: Ford
Default
If you are referring to the little picture up top, I believe that is a BroncoII Plus. Interestingly enough though, if you look closely at the 1984 Bronco II Ad you can see the latches on the rear windows
Old 08-27-2008, 11:35 AM   #10
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Haha that's funny as that is the other page to the brochure. I never noticed it there. They are the same B2. So in reality One "Did" exist at one time.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
