Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Special Interest Vehicle Use > Towing
Notices
Towing For questions about towing or to show off your tow rig.
Reply
Thread Tools Display Modes
Old 04-14-2011, 12:11 AM   #1
booblinker
booblinker's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger 4.0 4x4 XCab POS.
I use this vehicle for: Project, hope to be DD soon
booblinker is on a distinguished road
Default Trailer wiring issue. brake light and turn signal don't work with head light on
The brake light and turn signals work when the headlights are off, but when I turn the headlights on, the turn signals and brake light no longer do anything, it just stays lit. Trailer lights are 2 wire, dual filament, and ground to frame.
__________________
-01 Ranger 4x4 Xcab(it was cheap, hope it runs soon)
-85 ATC250SX (Tiny little tractor)
-85 ATC70 (125 lifan motor)
-84 ATC200S (Slightly built)
-83 CB750SC (It's close, but i have been lazy)
booblinker is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 04-14-2011, 01:06 PM   #2
Captain Ledd
Captain Ledd's Avatar
Vehicle Year: 1984, 1997
Vehicle Make: Ford
Vehicle Model: Rangers
I use this vehicle for: Literally everything.
My credo: If you're not making mistakes, you're not learning.
Captain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to all
Default
2 bulb? (red+reverse) or 3 bulb? (red+amber+reverse)
If it's the 97 (which should still be 3 color) I'd say something is shorting out between wires that run to the brake lights, jumping onto the others making them all just stay on when the tail-lights come on.
Do they change brightness if you step on the brake pedal?
My bet is frayed/shorted wires or the little adapter harness itself is toast.
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein
Never give up: http://www.youtube.com/watch?v=Y6hz_s2XIAU
1984 Ranger - std cab, long bed: The Deathtrap
302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear
1997 Ranger - std cab, short bed: Red Ranger
2.3L; M50D R1; 2wd; 4.56 gears; Explorer 8.8; ARB locker; 235/75R15 AT's
(soon to undergo 4x4 conversion )
Captain Ledd is offline   Reply With Quote
Old 04-14-2011, 02:57 PM   #3
booblinker
booblinker's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Default
Single bulb, two wire, grounds to frame. Brand new wiring and lights on trailer, new trailer wiring and convertor on truck. I've been told I probably hooked the taillights to the bright filement, and the brake/turn signals to the low filement. We will see when I get off work tonight and swap the wires.
__________________
Old 04-14-2011, 03:12 PM   #4
Captain Ledd
Vehicle Make: Ford
Default
Quote:
Ah, yes that will do it as well.
As for 2 bulb or 3 bulb I was referring to the lights on the truck. If the wires were shorting to each other it would still blink if you turned the signal on with the 2 bulb tail-lights because the tail light itself would blink.
__________________
Old 05-04-2011, 01:57 PM   #5
TomB1269
TomB1269's Avatar
Vehicle Year: 2002, 2005, & 2
Vehicle Make: All Fords
Vehicle Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
I use this vehicle for: Original Daily Driver/New DD
TomB1269 is on a distinguished road
Default
Looking at it from a schematic point of view, I think you may have switched ground and headlight.
If Headlight and turn are hot w/o ground, light goes out. Headlight cold & Turn hot, lights on.
If ground was headlight hot, then when headlights off Turn/brake would light. When headlights hot, turn/brake nothing as the ground side of the turn/brake would be hot and therefore no voltage difference no current flow in bulb.
If weak ground turn/brake will tend to pulse very weakly. Also if I am correct when Turn/brake is on & lights off you may see a dim glow from running/marker lights, and when headlights are on the markers will be full bright.
TomB1269 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
