EGR Vacuum Solenoid
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
1987 2.9 4x4 xlt. It seems that when i turn off the engine the EGR Vacuum Solenoid bleeds down making a buzzing sound. Anybody ever had this happen.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Damn, a million of these made and i got the only one that has this problem, whats the odds.
Nah, mine used to make that same noise. I always assumed it was normal.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Cool, did a top end and it had it before so i assume its a bleed off from EGR. Its not as Pronounced now and duration has narrowed. Dirty
Die.Fledermaus
4
State of Jefferson, USA
2.0 (4 Cylinder)
0"
I normally get that buzzing noise also, red/green hard vacuum lines to the fenderwall thingy.
I thought it was a feature so one could find the front of the vehicle when it was really dark outside.
kimcrwbr1
46
maplevalley WA
2.8l
Under the round cap is the bleed filter pull the cap and filter and spray some wd in after you shut the engine off. Clean the filter with dish soap and dry it out then put back together. That filters the air bleed that closes the egr when the computer tells it to.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Well that seemed to work. Particle build up in the filter. Got a little dirt out of the filter when i cleaned it with soap and water. Ill keep my ear open. Thank Dirty
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
worked for 2 days back again.
