'02 Ranger w/3.0L - Question?
GETRDUN
FORD
I am a long time F-150 owner, but recently bought an '02 Ranger w/3.0L, 2WD, and A/T. The truck has 123,000 miles. I am using 4qts. Valvoline 5W20, and 1qt. Lucas stabilizer as lubricant. The motor is strong.
My question is: At an idle, engine makes a ticking sound. Is this normal for this motor? Also, coolant is brown. Is it normal for this to happen in this motor? I have run V8 engines my whole life, this V6 is a first for me, and I want to learn all I can. Any input will be appreciated. Thank you.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
615
Central Indiana
I'd flush and fill the cooling system. Brown coolant is not normal, but it could just be old.
My 3.0 has always ticked a little. It's kind of quiet though. Sounds like valvetrain and injectors clicking on/off. You can only really hear it when the hood is open. If your ticking is loud enough that you can hear it while sitting inside your truck, there may be an issue.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
I would get rid of the Lucas and just use regular 5w20 with no additives. As for the coolant, it's possible someone put the wrong kind of antifreeze in there and two different chemistries mixed. The correct coolant to use is Motorcraft Premium Gold, or Zerex G-05 which is available at Napa. It is a light yellow/gold color. I would flush out the cooling system and refill with the correct antifreeze.
rodburner66
DuBois PA
I just replaced the cam position sensor in my 02 ranger 3.0 ...it made a slight ticking/chirping sound.my bro, a lifelong wrencher, pulled serp. belt to eliminate all pulley & idlers ,alt. & PS pump .It's a half dist. shaft in the same place as one( a dist. ) would be.right behind intake @ left center, easy fix .saw threads on here or another ford site cant member which , google it
GETRDUN
FORD
Thank you for the replies, I appreciate it. My best to you.
Kirby N.
March Truck of The Month
