3.0 Swap questions
'08 450
i was looking through the tech section and all the 4.0 swaps are done on older vehicles. i have a '98 ranger and i'm looking to do a 4.0 swap. I've heard the trannys are interchangeable then i've heard thay are not. So lets say i get a 4.0 motor out of a '99 ranger. Besides exhaust manifolds and a computer what else will i need to swap?
Edit: thanks for the responses.
Ranger44
23
Illinois
FORD
4.0 OHV
You'll need the 4.0 tranny, engine, computer, exhaust manifolds(maybe even the y-pipe), plastic air intake, wiring harness, radiator, maybe motor mounts, etc, etc.
The best thing to do is have the parts vehicle on hand so if you forget the little things you can always go back and snag it. Other than that these are the major components you'll need for the swap.
'08 450
on the tech section it says the 3.0 and 4.0 used the same tranny untill '00
BlackBII
Ranger Custom
Truck of Month
982
UT
What he said ^(Ranger44)
The 3.0 and 4.0 use a different bellhousing bolt pattern. So a 3.0 tranny will not bolt up to a 4.0.
So you'll need everything previously mentioned.
'08 450
so there is nothing interchangeable between the 2 at all?
BlackBII
Ranger Custom
Truck of Month
982
UT
They are from 2 different engine families, sorry bro.
Ranger44
23
Illinois
FORD
4.0 OHV
They use the same tranny, the bellhousing patterns are different.
The bellhousing and gear box are interagal. Therefore you just couldn't switch bell housings or anything.
'08 450
that sucks guess it's gonna get another 3.0
