Skyjacker class II 6" tire fitment pics
RICO9
07/2014 OTOTM Winner
35
SL,UT
Title says 84.
Furd
2.8L w/ Chevy TBI.
Looks good! Do you have any pics of the custom dash? looks pretty cool!
4x4junkie
580
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
4x4junkie Thanks for the link. I may see if the shop can make an arm while im getting it aligned. I just measured it out and even the "extreme" drop arm wont be long enough. Can you think of any other fix's besides a whole new steering setup?
The FA600 drop arm is usually adequate for a 6" lift, though as you noted, it still isn't perfect. Having an even bigger arm on there would be torture on your steering gear though (I definitely wouldn't recommend it).
Next-easiest option would be taking a Superlift Superrunner steering kit and modding it (or building something yourself loosely modeled after Superlift's K-Link design). This typically works best IMO for a trail truck, and is what I run on mine. I don't see much reason to go crossover/swingset unless you plan to be jumping it or pushing it to it's limits at speed.
You might poke around a bit through the Steering section here, we've had a few members who have built various setups, many of which have worked well for them. At least you can get some ideas. :icon_thumby:
H311RzR
U.S. Military - Active
2.8L
i Appreciate all the info. I will jump it once in a while....just to see. but until i do the 302/dana 35/8.8 im most likely not going to do anything serious....unless I break something..then all bets r off...lol. i cant believe the "extreme drop pitman arm is soo freakin expensive....its almost as if they "corporate companies" planned it that way.... bastards!!
Kirby N.
March Truck of The Month
