92 Ranger console arm rest bracket replacement
jaycal
Noob looking for some help.
I'm trying to figure out how to remove the console arm rest bracket from the arm rest :dunno:. The bracket has busted in half and I need to replace it.
Found some sources for the new bracket but could use some insight as to member recommended online parts suppliers as well.
Thanks in advance for any assistance.
J
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
I usually use a small Air powered recip saw (an IR I forget the model number)
and cut the steel shaft.
after that it comes right out.
If you want to avoid that you can either seek another armrest that's
already upgraded to the '93-up bracket(ford's name for it) at your
local u-pull-it.
AD
Members online
Shran
April Truck of The Month
