hi from los angeles california
reyes1478
2.3
Hi I'm Roberto from sunny southern Cali. I own 95 Ford Ranger XLT V4 2.3L SOHC. While replacing the valve cover gasket the vacuum hoses broke. What is the correct replacement hose specification or size?
Uncle Gump
Token Old Guy
13,166
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Take the pieces of broken hoses to the parts store and buy the same size hose.
DannyG
9
Grand Forks, ND
Welcome!
If it is plastic you might not be able to get a replacement. Fuel line should work for the vacuum system.
Alternately, a replacement such as www.amazon.com/dp/B012RMD5X2 should also work. I believe the vacuum size is 1/4" or 6mm.
Kirby N.
March Truck of The Month
