Mazda vs ranger front hub
babybigfoot
Mississippi
1996 Mazda B400
I have a 96 B4000 front end torn down. When I pulled the rotor off of the spindle there was a piece of rubber left on the spindle. Looked like it was up against the seal on the back side of the rotor. It rides on the same surface as the hub seal does but doesn't look like it was connected to the hub seal at all. Looking at a breakdown of a ranger, it looks like a metal piece that in the Haynes manual they call a dust seal. But this dust seal in the book looks like a metal piece. They look nothing alike but they are pretty much in the same place. Is there a difference between the two?
One last question, The spindle seal that is in the back of the spindle where the needle bearing is on mine is a one piece seal with a metal flange that sets inside a plastic ring. When you get a new seal from the parts store they give you a flat rubber O ring and then the plastic ring and a metal cup with a rubber seal going around it. I think this may all tie in together but I am at a lost.
Can anyone explain to me the whole backside of the hub and spindle? Or even better does anyone have a good breakdown of the hub/spindle? Is this the only place that maybe Mazda and Ford differ?
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
theres variations in seals that fit the same application.
the 96 mazda has all the same parts axle wise as the ranger.
did you look in the tech library?
babybigfoot
Mississippi
1996 Mazda B400
By any chance cam you explain what the flat rubber seal was on the backside of the hub? And why so many parts come with a spindle seal kit? And how all the parts are supposed to go together. Sorry for the stupid questions but this one has really got me stumped
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
its a slinger/spacer
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
Like Bobby said, there are a few different ways these are put together.
You take off the wheel. The thing shaped like a top hat is the lockout. It has an o-ring that seals it against the hub/rotor. Take off the lock nut, washer and bearing adjustment nut and pull off the hub/rotor. Now you are looking at the spindle. 5 nuts and the spindle comes off. That's where it can vary, but it isn't that important. There is usually a disk in there that you can pull off by hand. That is generally all plastic. On the axle outer, there is a rubber seal on a steel disk that you can't pull off by hand. I think I've seen a felt pad on some. Don't need it. Inside the spindle there is a seal which you can pull out with a finger and then the roller bearings. That all lasts forever if you put a finger of grease on it once in a while.
If you post pictures of the parts we can help you better. And if you have a Haynes or Chiltons, those are very confusing. If I remember, I will try and get you a picture from the Ford manual.
babybigfoot
Mississippi
1996 Mazda B400
Ok, I have them laid out. The one on the right is the new kit. I know the rubber on the top has a metal sleeve that has to be pressed on the axle. The sleeve is at the machine so now. But the center is what came out of it. The seal has a metal ring around it that the kit on the right doesn't have. ? That is one of my questions. And the rubber ring below the spindle, I can not find anywhere. The best I can figure is, is this takes the place of the dust shield. Anyone have any knowledge on this? Or even if any of this is right?
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
babybigfoot
Mississippi
1996 Mazda B400
Ok well it's not letting me upload pics. Saying something about security tokens, whatever that is. Keeps giving me an UPLOAD FAILED. Thanks though
Ranger850
Doesn't get Sarcasm . . .
4,680
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
I cant post pics from my computer, ( Security Tokens or whatever) but I have no problem posting pics from my phone, Some resizing my be required tho.:icon_thumby:
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
My suggestion, get free forum posting software like Tapatalk, it's really really easy to post photos.
These photos help any?
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
this side?
babybigfoot
Mississippi
1996 Mazda B400
It may be the grease seal that is the rubber piece that goes behind the hub but mine is flat and I can't find a part#. But my bill of material says that I don't have that seal. But who knows maybe someone before me added that in
babybigfoot
Mississippi
1996 Mazda B400
Ok I think I have it finally figured out. The first pic is of the spindle, the rubber seal that went behind the hub, the old seal and plastic washer, and then the new kit.
The second pic is of the old seal with the metal rigid seal. It has to be pressed in just like any other seal. The new kit has a soft rubber seal that just falls down on top of the bearing. It's soft and pliable like an o-ring. I have installed the bearing in the spindle and with the new seal in it, it has about an 1/8" of play between the seal {with it sitting on top of the bearing} and the bottom of the plastic washer. Which I think that it will wobble in there and cause it to leak. Do I need to pull the bearing back out and only seat it in just a little so that the seal is held in place by compression from the plastic washer? Or do I find the seal with the metal ring?
And the third pic is of the rubber/metal ring that was behind the hub that I can not find anywhere. It's pretty much flat but it does have a little bit of a concave design around it. I think this may be a dust shield since it did not have one on it. But I did bend one of them up pretty bad while removing it. I can beat it back somewhat flat but was looking for new ones and to make sure that it is like it is supposed to be.
Sorry about the cut off pics but that is the only way I could get it to fit. But I'm sure that there is enough there to get an idea of what I'm talking about. Thanks ya'll for all the help.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I don't think I've seen a problem replacing any of that on two trucks, 93 and 94, with Dana 35s I think the old seal wasn't really a seal but more of a dust and water slinger. Also the inner spindle bearing doesn't get anywhere near the amount of Grease the wheel bearings get, and of course the axle only turns when it's in 4-wheel drive, which is not very often for most of us. The big grease seal on the back of the rotor, takes a good whack and a big block of wood to get it seated. We always replace them even though a lot of people don't.
babybigfoot
Mississippi
1996 Mazda B400
Where do you find the shield on the back of the hub that you just whack with a hammer? I'll replace them if I could just find them. And during the winter months I may run from work to the house with it in 4 wheel drive and the seal with a metal ring just makes a lot more sense to me.
Members online
Shran
April Truck of The Month
