Shran
Junk Collector
Solid Axle Swap
Truck of Month
- Mar 4, 2008
- Reaction score
- 4,791
- Location
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Original Poster: shran
Difficulty: 2 out of 10
Time to install: 30 minutes
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation:
I have not seen this topic covered before, so here goes. If you have an 83-86 truck, chances are, you have the gauge cluster that has either dummy lights or engine gauges on the left side but no tach.
I wanted a tach and did not want an aftermarket one since it's just one more thing to mount somewhere, so I snagged a gauge cluster from an '88 Ranger at the junkyard. I soon discovered that it is not a plug-and-play affair, as you may know if you've tried this.
The problem lies in the fact that 83-86 trucks are missing some wiring required to run the tach, specifically the tach signal wire itself. Everything else is there, you just need to repin the green cluster plug and add ONE wire!
I know for sure this works on an '86 with '88 gauges. YMMV. I will not attempt to tell you what color wires you need to move, only what wires go where, as your wiring harness may have different colors than mine (and likely does.)
Tools Needed:
- Philips and torx screwdrivers
- Small flat screwdriver (to remove wire pins)
- Wire cutter/crimper
Parts Needed:
- 87-88 Ranger/B2 gauge cluster
- one or two extra wires from the brown cluster plug on the donor vehicle (6 inches or so is enough.) Or just clip the whole brown plug from the donor
- 3-4 feet of wire for tach signal
- crimp on splice connector
- red butt connector
Step 1:
Remove lower dash trim, ashtray, and gauge bezel. Disconnect speedometer cable, remove (4) gauge cluster mounting screws from the corners of the cluster. Pull it out of the dash, disconnect the two harness plugs from the back. Set old cluster aside.
Next, check all the bulbs in the new cluster. Typically there are some burnt out.
Step 2:
Hold up the GREEN plug, wires facing away from you, observe the top right - there is a chunk of plastic sticking up next to the clip. This prevents you from plugging this into the new cluster. Break it off.
Step 3:
Holding the GREEN plug, wires facing away, observe inside the slotted part that there are clips holding the wires in. Also, notice that on each side of the plug, each wire is numbered 1-18. Wires 1-9 are what we are changing, 10-18 are not important.
Use your flat screwdriver to release the clips while pulling the wires out ONE AT A TIME. Below is the correct sequence for the factory pinout AND the new one - make yours match the new pinout:
NOTE here that PINS 3 AND 4 may be different depending on the gauge cluster you get! It is best to check NOW with the donor vehicle!
Using the extra wire you grabbed with your new cluster, insert this into either pin 3 or pin 4 (MINE WAS PIN 4 - DOUBLE CHECK WITH YOUR DONOR - VERY IMPORTANT!)
Step 4:
Using the length of wire you have, splice into the GREEN side of your ignition coil harness under the hood. Run this wire into the cab and up to the gauge cluster area, and use the butt connector to attach it to the new wire you added to your green plug.
Step 5:
Attach both harness plugs to your new gauge cluster. Start the vehicle, verify that tach is now working. If so, verify that your other gauges are working, reattach speedometer cable, put the dash back together, and you are done.
If it does NOT work, here are some possible causes:
- spliced in tach wire is not connected to coil, or not connected properly.
- Pins 3/4 reversed.
- Other wiring issue (grounds, loose plug, etc.)
- Tach is simply broken, or cluster is otherwise damaged.
Brief Explanation:
Tools Needed:
Parts Needed:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
