Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Suspension & Armor > Off-Road 4x4 Suspensions
Notices
Reply
Thread Tools Display Modes
Old 04-10-2012, 06:20 PM   #11
CHKNFKR
CHKNFKR's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Spending my hard earned cash
CHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant futureCHKNFKR has a brilliant future
Default
The ttb setup is capable of some pretty amazing things. It beats the living snot out of sla setups day after day. If modified appropriately a ttb setup can roll with the big dogs.
The big problem with ttb is most people don't understand how it works and how to maximize its usefulness. Most of the time it's easier to sas than it is to work the bugs out of the factory ttb system.
__________________
Quote:
Originally Posted by daniel3507 View Post
This pick up makes my pecker perk up
Quote:
Originally Posted by gwaii View Post
all my layout,bend allowances,and cuts are figured out using a neural cognitive software system.
Quote:
Originally Posted by super91(2.3) View Post
I can see myself goin to the gas station now and buying under a dollars worth of diesel and just dispensing it right onto my body...
CHKNFKR is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 04-11-2012, 12:08 AM   #12
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
Quote:
Very true if you factor in cost vs. durability (especially while building on OEM platforms), however with enough budget a SLA-IFS tends to have an advantage because of it's "cleaner" (as well as highly tunable) wheel travel characteristics (especially as speeds go higher).
Quote:
Originally Posted by cdawall View Post
You don't "need" a lifted truck. Solid axle's will outperform TTB's in a lot of offroad situations. That's all I was saying. You will never get even similar flex from a TTB that is just part of the independent suspension any "flex" typically gained is due to frame flex.
You're saying this is all due to frame flex?
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 04-11-2012, 05:32 AM   #13
spash94
Vehicle Year: 94
Vehicle Make: ranger
Vehicle Model: 4x4 splash
spash94 is on a distinguished road
Default
Becides getting a 6 inch drop pitman ARM from sj is there anything else I need to know I was going to buy a brand new stock setup and run the drop pitman just so the steering was tight.
spash94 is offline   Reply With Quote
Old 04-11-2012, 06:58 AM   #14
cdawall
cdawall's Avatar
Vehicle Year: 2005
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: trails/daily driver
cdawall will become famous soon enough
Default
What flex am I looking at? Passenger side is dropping out with nothing under it drivers side is tucking with a rock. That's exactly how any ifs would respond to that situation. Just because it looks like a solid axle would doesn't make it flexing out. Don't get me wrong TTBs are great but its humanly impossible to flex one that's not how IFS works.
__________________
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60U, 38.5" TSL SX's, build thread
cdawall is offline   Reply With Quote
Old 04-12-2012, 03:35 PM   #15
prerunnerwannabe
prerunnerwannabe's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Getting distracted....
prerunnerwannabe will become famous soon enoughprerunnerwannabe will become famous soon enough
Default
If you look, the rear drivers side tire is dropped out so that the entire suspension is articulated to its max, so I'm pretty sure a solid axle with the same springs/lift would have done more or less the same thing under those circumstances.
But I could be wrong...
prerunnerwannabe is offline   Reply With Quote
Old 04-12-2012, 04:49 PM   #16
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Make: Ford
Default
Quote:
The Skyjacker pt# FA600 drop pitman arm should work fine if you're set up for 4" lift. I'd suggest a K-link setup for it though (less stress on the steering box shaft). A K-link or other setup would be mandatory if you want more than 4" lift with softer coils anyway.
For sure it would have.
I've concluded he must be playing a semantics card, because that post makes just about as much sense as a solid axle remaining rigid in that circumstance.
Fact remains, TTBs will outperform solid axles in a lot of offroad situations too. But there's more situations far & wide where either one would work about the same than situations where one can outperform the other. Some apparently just have a hard time realizing this.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 04-12-2012, 06:22 PM   #17
cdawall
cdawall's Avatar
Vehicle Year: 2005
Vehicle Make: Ford
Default
It would do similar I was simply pointing out IFS does not articulate like a solid axle that is purely its design.
There are ton's of situations that solid axles perform better. There is one situation that TTB's perform better and that is after you build the crap out of them (prerunning). This is the reason KOH guys prefer solid axles there are many threads on pirate about this exact thing.
__________________
Old 04-12-2012, 07:25 PM   #18
kryptonitecb
kryptonitecb's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: daily driver, trail ready
kryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nice
Default
If a solid axle flexes so well then why do the desert racers use ifs? Solid axles have their place and for the cost of a sas you can flex out a ttb. Plus if you really want to flex a solid axle you'll have to link it, kinda like how a ttb already is. For fairness solid axles are far stronger than a ttb.
Sent from road while ignoring traffic
kryptonitecb is offline   Reply With Quote
Old 04-12-2012, 07:35 PM   #19
cdawall
cdawall's Avatar
Vehicle Year: 2005
Vehicle Make: Ford
Default
Was that a serious question? IFS has the option of more travel deser racing has nothing to do with flex. If you read my post I mentioned it as well. In all fairness the jeepspeed guys do run SFA vehicles.
IFS will never flex. Flex is caused by one wheel pushing the other up or down. IFS cannot do that it is how IFS works. You can make a TTB drop out and compress better, but its still not a solid axle.
__________________
Old 04-13-2012, 10:12 AM   #20
prerunnerwannabe
Vehicle Year: 1993
Vehicle Make: Ford
Default
Ohhhh I see what you are saying now. See I understood flex as just another way of saying wheel travel. In that case yes, an ifs will never 'flex' like a solid axle does.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
