olds one ton...hmm
86MUDRCJ
8
Sheridan, CA
2.9
My dad had a one ton under his 78 f150 but it fit the gm pattern?then my gpa said it was an holds.so is it a 14 bolt or did Oldsmobile actually make an axle?
brinker88
11/2013 OTOM Winner
OTOTM Winner
36
Williamsport, Pa
4.0L
Here's a newsflash for you. Chevy, Dodge, and Ford 8 bolts up until I believe it was 2000 (?) Had an 8x6.5 bolt pattern so they're all interchangable. The newer 8 bolt fords have an 8x170mm metric bolt pattern
86MUDRCJ
8
Sheridan, CA
2.9
I didn't know that.thanks bud.+1rep
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,085
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Be careful on that, '?? chev 8-bolt won't fit '91 f-250. The center hole is slightly too small. Also there can be differences in stud hole sizing.
Richard
SAY789
Solid Axle Swap
6
Springfield Or
5.8L
97 was the last year of the standard bolt patter in fords. 99 and up is the metric
brinker88
11/2013 OTOM Winner
OTOTM Winner
36
Williamsport, Pa
4.0L
Thanks, SAY789, I couldnt remember the exact year
Staff online
Shran
April Truck of The Month
