Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
Notices
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 04-15-2012, 08:07 PM   #21
nb11
nb11's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger xl
I use this vehicle for: A-B
nb11 is a jewel in the roughnb11 is a jewel in the roughnb11 is a jewel in the roughnb11 is a jewel in the rough
Default
I mean, he wants to fit bigger tires. It doesn't sound like he wants any type of performance lift, doesn't want any trouble (read TIB camber issues) and wants something relatively cheap. I'm not the biggest fan of body lifts, but looking at his constraints and criteria, a body lift would be good.
OP: If you go the body lift route, expect to pay around $250 for the lift, then extra for bumper brackets, gap guards (so you can't see the space between the bottom of the bed and the frame), shifter extender, and steering extender. Then, you'll be able to fit larger tires, which will cost more than smaller tires, and will take re-gearing (expect $400-600 to have a shop do this).
It'll be expensive. Your best bet would be coil spacers up front, alignment, and a size or two larger (than what you have now) tires.
Here's a link to the tech library. Read everything here. Everything! http://www.therangerstation.com/tech_library/index.php
nb11 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 04-15-2012, 08:52 PM   #22
killj0y
killj0y's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger XLT Standard Cab
I use this vehicle for: DD and light duty
My credo: Fix it till its broke!
killj0y is a jewel in the roughkillj0y is a jewel in the roughkillj0y is a jewel in the roughkillj0y is a jewel in the rough
Default
Quote:
Originally Posted by blakeandress1 View Post
oh ok so if i do any body lift at all 31's will work ok? and you said ur gears are 3.73..is that stock or did you change them? cuz idk what gears are on my stock 95 2.3l 2wd...i mean if urs is the 2.3l 2wd and all ur stuff works fine without power loss then i got nuthing to loose
Nah stock but
They can very sometimes. check your driver door sticker and in the tech library is a link to identify what you have.
I agree but damn at that price range he can get a real lift for a few hundred more if anything...
If he feels confident he can probably do it himself and save big time...
__________________
96 Ranger 2.3l 2WD Manual 5 Speed
*Lock-Rite Locker
*4" Rough Country Lift
killj0y is offline   Reply With Quote
Old 04-15-2012, 10:02 PM   #23
6.2
6.2's Avatar
Vehicle Year: 2006
Vehicle Make: Ford
Vehicle Model: Ranger FX4 LevelII
I use this vehicle for: DD/Offroad
6.2 is just really nice6.2 is just really nice6.2 is just really nice6.2 is just really nice6.2 is just really nice
Default
Uh, expect to pay $250 TOTAL. Aside from gap guards, but you can make those yourself.
PA Body lift. Includes all bumper brackets and everything you need to complete the lift. No need to buy anything extra. If someone tells you otherwise they have no idea what they're talking about.
6.2 is offline   Reply With Quote
Old 04-15-2012, 10:11 PM   #24
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
I made splash shields for the front wheel wells to keep crap from being thrown into the engine compartment from the wheels out of tractor inner tubes.
I don't care for the gap guards at in the rear. IMO they look like exactly what they are... hunks of plastic to keep light from shining between the frame and bed.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 04-16-2012, 10:57 AM   #25
blakeandress1
blakeandress1's Avatar
Vehicle Year: 1995
Vehicle Make: ford
Vehicle Model: ranger 2.3l 2wd
blakeandress1 is on a distinguished road
Default
thanks o much for all the really appreciated help!!!
blakeandress1 is offline   Reply With Quote
Old 04-16-2012, 03:31 PM   #26
prerunnerwannabe
prerunnerwannabe's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Getting distracted....
prerunnerwannabe will become famous soon enoughprerunnerwannabe will become famous soon enough
Default
Quote:
Originally Posted by adsm08 View Post
You buy new gears and a master install kit, buy a bunch of tools like a dial indicator, a shoe-horn, a dummy tube, a torque wrench, etc. Then you remove the drive shaft, the wheels and brake drums, and the diff cover. Then push in on the rear wheel hubs, pull the C-clips out from the inboard ends of the shafts, and yank the shafts out. Next unbolt the bearing caps for the carrier, grab the carrier,and pull hard.
Now you have to remove the pinion nut, pull the companion flange off and hammer the old pinion out. Zap the ring gear bolts out of the carrier, you will want a pneumatic impact wrench, hand tools won't work well because of the high torque and thread locker and an electric one usually wont' cut it.
Next you have to install the new pinion and set the depth properly using selective shims and install the bearings and set the preload. Once that is done you have to install the new ring to the carrier and install the carrier back into the housing and set the backlash. Put some yellow goo on and spin it all and check the gear mesh pattern. If that's right you put the axle shafts back in. Might as well do axle seals while you are there, since you gotta take the shafts out to do that. Install C-clips, the rear cover, and the drums and wheels, and the drive shaft of course, and take it for a ride.
Personally, I'd never own a 4-cylinder of any sort with anything above a 5.13 gear. But that's just me.
Sounds simple enough
prerunnerwannabe is offline   Reply With Quote
Old 04-16-2012, 03:56 PM   #27
straycat
straycat's Avatar
Vehicle Year: 02 06 and 2012
Vehicle Make: Jeeps
Vehicle Model: 02 Grand Cherokee 4x4 4.0L 06 Wrangler X 5.7 Hemi 87 Samurai 4x4 2012 Wrangler JK-8
I use this vehicle for: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
You have to swap out the gears that are inside the middle area of your axles. You will have to take it to a shop and have it done since you have no idea what we are talking about. Front and rear (4x4) will be about $1,000 with parts and labor. Tires are another expense since you want them and then your speedometer will be off and you will have to correct that and your gas mileage will drop and that is another expense...lol!!! Join the club of upgrading your ride, Bro!!!
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
