a4ld
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I put a shift kit into my a4ld valve body. I found that one pan bolt hole is stripped and another is stripping. I guess someone before me over did the torque. I guess I'll have to put a Heli coil in or drill and tape to next bigger size. The kit does help but the a4ld still must be rebuilt. I also brazed in a drain plug. The brazing looked so good, but it leaks. I didn't expect that. Anyway, now it'll be easier to drain and remove to pan to fix it. I thought this would be a simple project, but it wasn't. It was a lot more work and aggravation then I expected. Though I should have expect that since that's the way it always is.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Ain't that the truth....
Tho it does make you appreciate the times things go right.
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
I want to rebuild this a4ld. I did a valve kit, and installed a drain plug. I can order a super dooper rebuild kit and have that on hand for when I take it out. But I suspect I'll find other things that will need to be replaced. I wonder if I order some things that frequently wear out, in advance, in case I need them, and just return them if I don't. I'd hate to wait a week to get needed parts while my truck is down.
