Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 05-17-2018, 09:02 PM   #1
CreepyCrawler
CreepyCrawler's Avatar
Vehicle Year: 1991 1996 2014
Vehicle Make: Ford Ford Ford
Vehicle Model: Ranger Ranger F150
I use this vehicle for: Under Construction/ Truggy/ DD
My credo: it is what it is
CreepyCrawler is on a distinguished road
Default Ford 300
Howdy fellas. I’m picking up a running 300i6 this weekend and am wondering what the best or along the lines of the best build would be for a low-medium hp but high trq inliner. The motor I’m purchasing is a 91 efi 300i6. I know I want to cam it but not sure what is best bang for buck and which will draw most low end out of motor. I’ve heard there are forged crankshafts in some of these motors... how to identify or easier just to buy a forged rotating assembly? Is it worth boring the block out to accommodate FE sized pistons? Which rockers with cam combo. Suggested valves? I’ve also heard of people going back to carb from efi... is there a larger gain in performance with lout the egr setup?
This motor is going into my ranger and space as well as more crossmembers will be accommodated for higher trq.
The ranger it’s going in will be a trail rig/crawler. I would like to be able to turn lower rpm’s with as much trq output as possible as my overall crawl ratio will be somewhere around 300:1
Any motor builders familiar with this powerblock feel free to give advice haha I’ve searched several threads on other sites but the builds I’ve read through only max at about 300ft/lbs. I would like to be somewhere in the 350-400 range before considering FI. Appreciate it
__________________
CreepyCrawler
1991 Ford Ranger HYRyder 4.0 5 speed stock
1996 Ford Ranger XLT Truggy -F150 HPD44/F9" 488s Alloy Shafts Detroit Lockers 6" 38.5x12.50 4.0 auto tube bed 1 piece drive shaft rear
CreepyCrawler is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 05-18-2018, 09:58 AM   #2
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Carbed trail rig/crawler?
I would go 351W if you think you need that much torque.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 05-18-2018, 10:37 AM   #3
CreepyCrawler
Default
Too much motor and money to build it for what I’m doing with the truck. Why spend 4K on a v8 when I can throw 1-2.5k at my 300 and put out the same trq
__________________
CreepyCrawler
Old 05-18-2018, 11:13 AM   #4
85_Ranger4x4
December 2013 OTOTM
Vehicle Year: 1985
Vehicle Make: Ford
Default
A late model W is 350lb-ft out of the box without touching a thing. EFI so it will run on its side if you want (your '91 300 would be EFI too though)
I don't mean to crap all over your idea just throwing that out there. A V8 would be easier to fit in a short Ranger engine bay.
__________________
Old 05-18-2018, 11:27 AM   #5
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
I can't help on the 300 specifically, but you will need to move more air to make more torque. At low RPM's, this isn't the easiest thing to do. Have you considered a small turbo along with a different cam? That would help with the lower end. It would run out of steam quickly, but if you tune it for 1-3.5k RPM it would make for a great crawler.
The 300 is quite long. There are some pictures in this thread, along with some arguing from internet tough guys. LINK
Another with more pics of the fitment. You will likely need to cut out your radiator support all together and move it into the grill. LINK
__________________
89-92 Rangers are best. Fight me.
1989 Ranger build - 4.0 swap, 7.5, Dana 35, 4.56 gearing, Lockers, 5" lift, Electric power steering
1976 Fiat Abarth 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Old 05-18-2018, 11:48 AM   #6
CreepyCrawler
Default
I’ve got a couple sbf laying around. Trust me I’ve considered the v8 swap. But I just wanted to make it an inliner. It was either a 4bt or or the 300 and decided to stick to gas as well as keep the train all ford... except tcase. Haven’t decid d yet on Atlas or 203/205 with lomax. And yes as for fitting it the grill support will be cut. Thinking about cutting out entire middle section of firewall and moving everything further into cab and drivetrain back. Radiator will be mounted in back seat or behind cab
__________________
CreepyCrawler
Old 05-18-2018, 11:51 AM   #7
CreepyCrawler
Default
And yes I would probably turbo the motor
__________________
CreepyCrawler
Old 05-18-2018, 01:48 PM   #8
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
Quote:
dude....really?? i mean fuking REALLY!!???!!
it is already the best of the best of the best for that goal...it is done.
the ranger will need no frame mods for one of these turds unless you boost it with a turbo....and that power level done reliably will be a huge expense.
are you going to be running 5 ton merritor axles and monster truck tires???? 300 to 1 could get away with a briggs and stratton lawn tractor engine and still blow dana 60 shit to hell. in this case a stock 300 6 in any flavor carb or efi would be just peachy....
not reading this well... but i know what it takes to build a street stock 300-6 champ that competed at flatrock speedway in the past that was besting 351's and cheap is not any part of that scenario.
not even close...
so ...for 5 grand i can fresh build a 500 hp 500 ft pound 351.....your saying for 5 grand you can build a 500 hp ....well 400 hp 650 ft 300 6....? 300 would have to be turbo...351 is n/a. just saying for anybody that has to ask these questions... equal money verse value....
regardless, you can buy the engines used with the same miles for 3-600 bux with a trans on them and 1200 into the 351 will still net more power RELIABLY then 1200 into the 300. with a much larger power range. i am assuming of course you want your off road adventure vehicle to be reliable....could be wrong here...
so you just want to be different....cool. nothing wrong with that;...
turbo, 8 psi.
cut the efi intake and mod it.
it will fit without firewall mods with a modified intake, turbo will make up for cutting and boxing the intake which kills the torque range by allowing easy fitment. but the turbo plumbing takes up the rest of the space
and it is still a pos. but shiny! with complicated tuning. but it will be a axle destroying monster from hell....and much faster. you sure as fawk wont need 300 to 1.
thats one way...and not cheap if you want it RELIABLE.
a carb version of the 300 fits easily compared to the current engine in my truck. i essentially have a big block and it fits just fine with straight axles...
a good 390 cfm 4bbl off road prepped with offy intake and decent header would be pretty good and way way less work.. not sure which cam i would want ... there is a shitload of them...pick your overall parts that get you to 300-1 and call the cam manufacturer with your goals and weight and gearing information...
but a propane mixer with a 500 cfm carb would be the easy button. deck the head and block for compression bump and just run propane with older offy setup.
this is a good way to go for what you mentioned. i would consult with comp cams extensively after i compression checked the engine hot, and looked at the bottom end to make sure it was solid. not sure i would go with the harland sharp stuff and a bunch of head work. i think you would be happy with a matched to propane cam and resulting compression ratio.
anybody that adds power to a ranger with more cubic inches because the engine area is increased heating the coolant and does not open up the core for a larger area is not thinking clearly, so that is a goes without saying. and your willing to mod the core accordingly so you have that.
so.
the efi engine is the best stock solution. by miles. but requires large work to fit. the torque range is solid and it runs pretty clean. it really is all you need with 300 to 1.....like double what you need.
a 390 4 bbl with proper cam and cleaned up and matched exhaust and intake will match the stock efi engine closely, much easier to fit...and with the stroke of the 300 will be "useable" off road with a proper spring loaded float setup and overflow bridge. will need to use all of the ignition upgrades and plug range.
this is not cheap but in your price range mentioned for upgrades.
solid propane setup on modern block/head setup with compression bump, again with a carefully matched cam will be great off road.
again...not really cheap...your deep into 351 territory but will work ok with minimal fitment issues.
me, i would just run the 300 stock with your goals. its a trail truck so modding the firewall for best balance is a non issue.
buy it.....do it....just drop it in there and get it awn.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 05-18-2018, 07:15 PM   #9
rusty ol ranger
rusty ol ranger's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Tetanus Awareness
My credo: A legend to the old man, a hero to the child...
rusty ol ranger has a spectacular aura aboutrusty ol ranger has a spectacular aura about
Default
Bobbys right, a stock 300 will do what your wanting just fine. The EFI motors are harder to build and theres very little aftermarket. The 300 came with 265ftlb@2000rpm in EFI dress. With a 300:1 ratio...good god son, you could climb the empire state building.....at idle.
That being said, only the "HD" version of the 300 had a forged crank, as well as better flowing exhaust manifolds, however i dont believe the HD version ever came with EFI, and it was generally used in applications such as dump trucks/busses (Up to 30000 GVW), forklifts, UPS trucks, etc. The one your getting is more then likely your garden variety 300. However, they are still plenty stout.
Try this site...
www.fordsix.com
__________________
I'm still doin' everything I used to do, it just takes a lil' longer now...
97 F250 460/E4OD------77 F250 400/C6
87 Ranger XLT "Rusty 2.0" 2.9/TK5
Member since March 2002
rusty ol ranger is offline   Reply With Quote
Old 05-19-2018, 06:58 PM   #10
CreepyCrawler
Default
Thanks for the info y’all. I’m leaning towards the idea of a simple cam, exhaust matchup and carb’d now. If the efi dress is truly that hard make fit it would only make sense. And yes idling up the Empire State Building or pulling it down at idle is the “plan” essentially ��
__________________
CreepyCrawler
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1994 Ford Ranger & 1995 Ford Bronco Meet and become 1 vehicle! FullSize Ranger Introduce Yourself 9 02-07-2018 12:22 PM
Ford Motorsports Supercharger has arrived for BIG WHITE Ford Explorer MuscleJunkie Ford Explorer's 0 05-31-2016 09:36 PM
1996 Ford Taurus Engine in a 1994 Ford Ranger RangerNielsen Need Urgent Help Fast! 14 04-28-2014 01:46 PM
1983/1984 Ford Ranger/Bronco 2 Ford Truck Shop Manual wildbill23c eBay / Craigslist Finds 0 11-21-2013 07:51 PM
2002 Ford ranger want to put ford explorer disc rearend 3.73 ratio in to truck austin_america Ranger Axles 6 11-25-2008 10:00 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
