gdk771
- Apr 26, 2008
- Reaction score
- 0
- Location
- georgia
- Make / Model
- Ford
- Automatic
I have oil leaks on my valve covers on my 96 Ranger 4.0. I was looking at the engine and it appears I can remove the valve covers without removing the upper intake like I have heard. The drivers side will be tight and the EGR tube from upper intake will have to be removed. Has anyone done this before or should I just plan to remove the upper intake also?
I was also curious if I should attempt to replace the pushrods / rocker arms? This engine has had a light tick since it had 140k on it. It currently has 215k but the tick has stayed the same level the past 12 years so mabey I should just leave well enough alone.
Thanks
Thanks
