Truck wont go
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
So My Dad's got a 98 f150, Extra cab with a 4.6. (I think he said its a 3:55 rear end)Not sure which tranny he has but here is the situation. He recently bought a 30 ft. Camper w/ Gooseneck. Added the fifth wheel hitch to his truck and I think some traction bars or something to help with the pull. He was not pulling the trailer the other day and truck was fine. He left his key on all night so he jumped the truck off to start and says it would not go, Puts it in "D" and nothing, no clunking around no nothing. Puts in in Low gear and is creeps at a snails pace. Said he flushed it and ran some LUCAS slip stop in it but nothing still. Any help on this would be greatly appreciated.
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
It sounds like the trans filter needs to be replaced. Flushing and filter replacement usually goes hand in hand.I think it is just a coincidence that it started doing this with the battery dying.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
I thaught "coincidence" too. THNX Craig. will relay the message to him, he's retired so he has all the time in the world to do this stuff.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,832
SW Iowa
Engine Type
V8
5.0
That truck is not intended for a 30' fifth wheel at all.
If he didn't tear the trans out of it he will. Or the little 8.8. The little 4.6 will beat its head against the wall for a long time trying, he will probably get tired of throwing transmissions or axles at it before it gives up.
He has a 4R70W transmission. I think they moved the VSS to the rear axle in '98 so he will need to watch for a trans with the port in it for the VSS if he is 2wd.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Couple things to check.
Does the fluid level drop when you start the engine? If yes start checking trans fluid pressures.
The shift tube in the column is known for breaking on those trucks. It can cause all sorts of problems. Usually the first symptom is that it is hard to get out of park.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
He says the shift indicator has been off. N = Drive and so on. in low it looks like its in drive. How much of this could be his problem.
Or is his tranny blown and he needs more truck for that Camper
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The shift needle being off is probably just that. The needle is pulled along by a little nylon string, similar to fishing line, and it stretches over time. It is under constant tension from the return spring. There is a little thumb wheel under the dash that can be used to adjust it.
If this happened after he towed that camper he probably grenaded the trans. Like 85 said, that truck was not meant to haul that camper.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
Thanks for all the input guys. I think he realizes he muffed up.:sad:
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
I got a 32 Ft travel trailer i tow with a 97 HD with a 460. No way on gods green earth id go to a 4.6. Id even think twice about a 5.4 or 351W. Id look for a 92-96 F250/350 with a 460 (or 7.3 PSD if he wants to spend more), or at bare minimum a V10 superduty.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
In the right truck, with the right gears, I think a 5.4 could do it. It certainly won't be as happy about it as a 460, or a 6.8, but it would do it.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,832
SW Iowa
Engine Type
V8
5.0
A 5.4 SD won't play fair.
Our '04 F-250 5.4 is the same gutless turd running around with a service body and back seat full of tools as it is full of tools and with a tractor on a car trailer. Dunno how but it rallies the troops and doesn't slow down any.
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
I'm pretty sure the 04 5.4 had the 4r100 behind it.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,832
SW Iowa
Engine Type
V8
5.0
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
I was wondering. I know my manual 4406 came out a 03 5.4 f150 with the 4r100
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,832
SW Iowa
Engine Type
V8
5.0
Only F-150 7700's, Lightnings and a few select Supercrews had the 4R100, they were not overly common in a F-150.
Staff online
Shran
April Truck of The Month
