Name that sound?
2A GUY
Mansfield, Ohio
2001 Ford Ranger 3.0 4x4
Unsure what this sound is...best way I can describe it is a click sound (similar to what a heating element does when it’s pre-heating/maintaining heat in an oven/stove).
Should be able to hear it in both videos.
https://youtu.be/125zvIF_HJQ
https://youtu.be/TKs1cEn64Ns
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,386
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I couldn't see your A/C compressor. Do you have climate controls in a setting where the A/C is on and cycling? If I remember correctly, those settings on the older Rangers were the A/C positions and the defroster positions. Newer Rangers, the split vent/floor setting turns it on too.
Just throwing it out there since that sounds like what my A/C does when it's cycling.
2A GUY
Mansfield, Ohio
Defrost was on, not the AC.
sgtsandman
Ham Radio Operator
12,386
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Most Domestic vehicles have the A/C on with the defroster to clear the window sooner and better.
2A GUY
Mansfield, Ohio
Good to know...thanks. Just got the truck...it has some issues...trying to figure out if I flopped or just need to put some money into her.
sgtsandman
Ham Radio Operator
12,386
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Confirm it. Look for the A/C compressor and see if the sound matches the cycling of the clutch turning on and off. I might be right or I might be wrong. I'm just some guy on the internet. "Trust but verify."
Fordblue213
6
New Orleans, LA
That's the AC compressor clutch cycling. On defrost, the compressor runs to cool and dehumidify the air and the heater core reheats it so you have hot, dry air to get the moisture off the windshield.
Sounds like it is short cycling due to being low on charge, or its really cool/cold where you are and not taking much to pull the low side pressure down.
Fun fact: the vacuum controls default to defrost if a vacuum line breaks for safety reasons so you don't have a windshield you can't see out of if the controls die.
Kirby N.
March Truck of The Month
