Is the 2.3l alternator the same as the 3.0 and 4.0?
Ken727
St. Pete, Fl
On ebay they look like they qre all listed together. I just wanted to make sure.. maybe get a product number? I want a high output for stereo, lights and stuff like ike that.
Sent from my SM-N950U using Tapatalk
Ranger850
Doesn't get Sarcasm . . .
4,658
Tallahassee Florida
Stock 2"
Stock
From what I understand, and I may be wrong, but I have heard of people using a Taurus alternator for what your talking about.
8,290
The Year of your Ranger will matter, Ford used 2 different 2.3l engines in Rangers
In general, no, the 2.3l engine used different mounting than the Ranger V6 engines, so not the same alternators
List of Ranger alternators here: https://therangerstation.com/tech_library/alternator.shtml
I would add the electrics you want before replacing alternator
With all electrics on, if head lights start to dim at idle then you will want a higher amp alternator
Alternators only output 60% of their amp rating with engine under 1,000rpm, idling
At about 1,500rpm, and above, is when they output 100% of rating
So a 100amp alternator has 60amps at idle and 100amps above 1,500rpm
Ken727
St. Pete, Fl
You get the idea ranger850.
Dang ronD loads of info. Good to know that about alternators at idle. I dont have a number but maybe 30% increase, and a big 3 wiring upgrade. I only have the single cab for speakers.
Kirby N.
March Truck of The Month
