Has anyone here ever used urethane bushings on their 2wd front i-beams? I'm gather parts to swap 95-97 2wd front beams in to my 87 single cab V8 swap truck. In order to gain the braking upgrade..
Hopefully all these new parts will also help with the highway twitchy-ness my truck has. Toe is set perfectly. I'm thinking it needs more caster. It only has dr. +2.1 - pass. +2.4 degrees of caster right now which seems to be too little caster according to the specs I'm finding on here. The camber is only off on the passenger side which reads +1 degree camber, but it does pull rather hard to the right. All bushings underneath look pretty new and I think the P.O. replaced all of them, but I'm doing the beam swap so I might as well put all new poly bushings in there...
I'm looking at these bushings, and I assume I'll have to re-use the pressed-in metal cup the bushings ride in, or try to source new ones??
https://www.energysuspensionparts.com/4.3119
I also assume these will work for the radius arm bushings?
https://www.energysuspensionparts.com/4.7110
Along with new heatshield cups: https://www.rockauto.com/en/moreinfo.php?pk=203606&cc=1138104&jsn=507
Although I was curious about these. I'm not sure how they're used exactly.. I've never seen anything like them. They appear to raise or lower the rear end of the radius arms by twisting the bushings somehow? https://www.moog-suspension-parts.com/moog-k8746
So... Any thoughts or experiences are appreciated.
GB
GB
