1992 Ranger: Headlights Flicker Off and On Unexpectedly - SCARY
rangerenthiusiast
2
Hudson Valley, NY
4.0
Hey, all.
Just picked up a 1992 Ranger Custom (4.0, A4LD) with a bunch of problems, which I’m slowly addressing. Electrical issues are something I’ve never been good with however, so I’m reaching out in case anyone has any advice about one of them in particular.
What’s happening is that I’ll be driving home at night after work, when all of a sudden, both headlights will flash on and off irregularly without warning. Doesn’t seem to matter if I click between high and low beams (though I think it usually starts when the highs are on). It’s pretty damn scary because it often doesn’t seem like they’re going to come back on and I have to drive dark windy roads that deer like to frequent. I plan to clean the contacts up on the back of the headlights, but with the symptoms being what they are, I really think that something must be shorting out somewhere (maybe a bare wire contacting the frame?). :icon_confused:
If anyone knows of particular trouble spots on this vehicle that cause similar shorting problems, please let me know so that I have an idea where to start looking. Thanks!!! :icon_thumby:
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,339
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
The headlight switch is known for failing. When I replaced mine, it showed signs of overheating. I would examine that first. If you had a short that stayed shorted for the amount of time you mention, that would probably blow a fuse. This is more likely a loose connection such as bad switch contacts.
Sent from my SM-G920V using Tapatalk
rangerenthiusiast
2
Hudson Valley, NY
4.0
Hey, thanks a lot for the quick reply! I’ll pull that part of the dash/console and find the switch. Anyone know where I can order a new one from? No Ford dealerships close by me.
Again, thanks, eric. :icon_thumby:
fastpakr
Forum Staff Member
TRS Event Staff
2,789
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Rockauto can ship it to you.
https://www.rockauto.com/en/catalog/ford,1992,ranger,2.9l+v6,1137833,electrical-switch+&+relay,headlamp+switch,4472
Or you can get one from Amazon. They've got the Motorcraft unit in stock for $36 shipped.
https://www.amazon.com/dp/B000IYK6YI
If you have any chain auto parts stores in town, they've probably got it as well.
rangerenthiusiast
2
Hudson Valley, NY
4.0
tinman_72
136
North Georgia
Engine Type
2.5 (4 Cylinder)
2.5
2WD / 4WD
2WD
Factory
Total Drop
None
255/60R15
RoHS compliant
I had the exact same problem with my '93. I was told by people on this forum that the problem was the switch. I spent around 100 bucks to buy a brand new one from Ford. It made no difference. Turns out it was the relay. Ford wouldn't take the switch back because it was an electrical part.
Check your relay first.
rangerenthiusiast
2
Hudson Valley, NY
4.0
Hey, thanks tinman. I’ve found the switches for as little as 9 or 10 bucks online, but I also like the idea of checking the relay. Do you know if it’s located in the black box containing fuses under the hood? As I mentioned, I’m terrible with electrical issues.
Thanks again. :icon_thumby:
loknrok
I have an 88. Happened to me. Check the large electrical plug inside the column for the high beam/turn signal switch. I took off the housing and jiggled it around while stranded at night. It flickered on and off. I cleaned the connections with WD-40, and made sure it snapped on good. Problem fixed!! Hope this helps
Sent from my LG-LS993 using Tapatalk
rangerenthiusiast
2
Hudson Valley, NY
4.0
Thanks, loknrok! I’ll give it a shot! :icon_hornsup:
tinman_72
136
North Georgia
Engine Type
2.5 (4 Cylinder)
2.5
2WD / 4WD
2WD
Factory
Total Drop
None
255/60R15
RoHS compliant
I was mistaken about one small detail: It was over a decade ago when this happened to me but if I recall correctly, I could pull the high beam lever back and the highs would come on but if I pushed it forward they would flicker on and off just like the low beams. That is why I was told that it was the multifunction switch in the steering column, not the switch. (Do yours stop flickering when you pull the lever back?)
The way Ford sets it up is all the amperage that the headlights draw go through the switch in the dash and the multifunction switch in the steering column. No matter how often you replace the switch, the plug for it will always melt. I installed a universal relay ahead of the switch and my problem went away. What this did was make it so that the only amperage going through the switches is what the relay draws to open and close. When I did this I saw a very noticeable increase in headlight brightness.
rangerenthiusiast
2
Hudson Valley, NY
4.0
So, oddly enough, the problem seems to have resolved itself, at least for the time being. Maybe the truck just sat too long and corrosion built up on the contacts or something. Maybe the issue will come back. So many other issues to deal with, so I’m happy if it stays away for a while.
It does bring to mind a related issue though, which is that the lights are not very bright, due to the lenses being that plastic crap that I hate so much. I’m not into having them resurfaced, as I paid to have that done on my Jetta and it didn’t last. Does anyone know if there’s an aftermarket upgrade set made from glass? Pretty sure my ’83 Ranger had glass headlights, but I’m also sure they wouldn’t fit unless you swapped the front ends (which I’ve thought about doing many times, but there are just too many other priorities).
Have I mentioned that I hate plastic lights?
Staff online
Kirby N.
March Truck of The Month
