1986 ranger 2.9
mattlaine86
florida
ford
2.9
I've got an 86 ranger that ticks when I start it and other times I start it and it doesn't tick can anyone help me I already had to do head gaskets and now this please help. and some times its extremely loud and other times you can barely hear it.
86MUDRCJ
8
Sheridan, CA
2.9
When was the last oil change? Mine does it when it's about due. Also these things are pretty known for it. At least that's what I'm told.
mattlaine86
florida
ford
2.9
i just did the head gaskets not even 500miles ago and it never ticked until the head gaskets went
jhammel85
Guest
Did you change the oil though? You should really flush it with a few cheap oil changes after its gotten some antifreeze in it
Sent from my A500 using Tapatalk 2
mattlaine86
florida
ford
2.9
i changed the oil 3 times and its clean. someone told me it could be the fuel injectors how the ticking is on and off
mattlaine86
florida
ford
2.9
Could it be the valves i heard if you dont put the springs back were you took them from it will make the motor tick because i changed the injectors and it still ticks but when i drive it it stops ticking but when i shut it off and turn it back on it ticks
ranger2.9
indiana
87
87
89
ford
2.9 2.3
These things are natorious for ticking rocker arms. The tubes get plugged with gunk or the oil passage off the cam journal gets restricted. Clean oil is a good idea. My guess would be if you just put head gaskets on that the rocker arms are not adjusted properly or removing the head knocked some sludge loose in the rocker tube restricting it. You can take the plugs out of the end and clean it. My first guess would be rocker arm adjustment. Off hand I cant remember the specs but a search here should reveal a post.
Staff online
Today's birthdays
Kirby N.
March Truck of The Month
