headlight/highbeams dont work, runninglight/passing-highbeam do work
bluemeate
ranger
from the research i have done, i take it this is a common problem with the dimmer switch or something?
2000 ford ranger, symptoms
-headlights are out
-highbeams wont switch on, light on cluster wont illuminate
-highbeams will flash on with the lever, light on cluster will illuminate
-running lights work
I checked the fuses, all is fine
then i took apart the front panel and found these wires are corroded but still intact
http://i.imgur.com/7pj5ZRC.jpg
now for my questions
1.how does one use a multimeter (my roommate has one) and how can i use it to make sure the wires work
2. which piece is the dimmer switch? how much are they brand new? should i just go grab one from pick n pull?
3. how much would a shop charge me to fix this?
-also i searched 10 pages back and couldnt find anything with enough info to make things clear so i made this thread,
here are two relevant threads i found
http://www.therangerstation.com/forums/showthread.php?t=125335
http://www.therangerstation.com/forums/showthread.php?t=144141
thank you
bluemeate
ranger
from the website
http://www.justanswer.com/ford/69hk0-ford-ranger-headlight-dimmer-switch-located.html
The dimmer switch is incorporated into the multi-function switch . Start with making sure the #12 fuse in the interior fuse panel isnt blown and if so see if you have battery voltage with the light on at the DB/O wire and the Red/yellow wire at the multi-function switch with the key on and the light on, if so and still no headlamps, suspect the multi-function switch has failed.
not 100% sure what it means but the yellow ones lit up with the bulb tester thingy but the red X ones did not
http://i.imgur.com/KbFiiab.jpg (obnoxiously large image)
i think this means my dimmer is bad?
also #12 fuse is fine
chicagodude
2
Ranger
I ended up replacing the wires and terminals on that switch on the dash. I bought another switch and used part of the plastic connector. The wires that powered the headlights were very corroded. I cut off the old terminals and spliced on new wires with new terminals. After replacing the terminals, I had no more problems with the lights going out.
bluemeate
ranger
so i picked up 3 things from pick n pull
1. (2) headlights
2. dimmer switch
3. non-corroded replacement wire-harness-plug-thingy
I think i will replace them all in that order
bluemeate
ranger
so i picked up a wire harness from a 95 explorer that had 8 wires instead of the 7 that mine had. i matched them all up except for that one extra wire which i just electric tape'd shut.
now i only have one headlight and my blinkers dont work :x
help, please!
bluemeate
ranger
I replaced the 8wire harness with the proper 7wire harness and the right lowbeam still wont work
The blinkers work, high beams work, everything on the dash works
I even replaced the right lightbulb harness and it still wont work, I am going to cry
Help
V8RangerBoy
Let's backtrack and clarify here.
With the lowbeams on, only the left bulb works? With the high beams on, both bulbs work?
Staff online
Shran
April Truck of The Month
