2000 F150 V6, what T-case?
pjtoledo
2,955
Toledo Ohio
Fords
3.0 2.3
found a manual T-case in a 2000 F150 V6 auto tranny. any chance it's a BW1354? or will bolt to a Ranger M5OD?
will the shifter fit a BW1354? can it be easily adapted?
1FTZF1828YNA50824 if that helps.
couldn't get under it to look, probably too big.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,767
SW Iowa
Engine Type
V8
5.0
Should be BW4406 and completely incompatible with a RBV transmission.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,767
SW Iowa
Engine Type
V8
5.0
Not to mention the incompatibility with the frame.
Actually rather popular for V8 swaps in 98+ trucks. IIRC fastpakr has one in his truck.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I thought there was a width issue. Too many transfer cases.
pjtoledo
2,955
Toledo Ohio
Fords
3.0 2.3
are 4406's worth grabbing for future use/resale?
no idea what they want for it yet.
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
I have a manual shift 4406 in my 98 5.0 Ranger.
Ranger850
Doesn't get Sarcasm . . .
4,682
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
fastpakr
Forum Staff Member
TRS Event Staff
2,831
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
If it's a manual shift 4406 and includes the linkage, definitely see what they want for it.
Adsm - it's a big case, but it definitely fits. One of the top bolts is a pain to get to on a Ranger install, but otherwise it's all good. With a one inch body lift it fits like it was made to be there.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
fit good. work great. way better then a 208.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,767
SW Iowa
Engine Type
V8
5.0
pjtoledo
2,955
Toledo Ohio
Fords
3.0 2.3
it was indeed a 4406,,,,44-06-000-021 to be exact. XL34-7A195-AC
that t-case, the entire shifter assembly/boot/stick is now at my place. got the front drive shaft and a baggie of bolts too.
Staff online
Shran
April Truck of The Month
