Under inflation warning light 2011 Ranger
Bluegillz
red wing,mn.
ford
Hello,
The under inflation warning light on the dash of my 2011 Ranger XLT 4x4,will not shut off.Yes,the tires are properly inflated and I've tried disconnecting the battery.
Thanks
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
The batteries in the sensors fail like any other battery. Usually they last around 8-10 years. My advice, live with it until you're ready for new tires then have new sensors installed.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Is it on, or is it flashing for the first 30 seconds after you turn the key on?
On means a low pressure reading. Flashing means a failed signal.
If it is just a low pressure warning then you should be able to get it to reset by driving. Sometimes they get stubborn and need the reset tool.
Staff online
Members online
Shran
April Truck of The Month
