dwhile
- Feb 10, 2019
- Reaction score
- 0
- Location
- Spartanburg, SC
- Make / Model
- Ford
- Engine Size
- 2.8
Old throw out bearing was making quite a racket. Dropped trans and replaced the bearing. Then, I had issues with old clutch cylinders. Replaced them, then had issues bleeding the system. Built a power bleeder that did the trick. Now, upon starting the truck and attempting to back out of the garage, it won't shift into gear. I can shift it into reverse with the engine off, but once it is started it won't shift. It'll grind if I attempt to shift into reverse with the engine running, but no other gear gives any grinding. Just won't shift in.
My thoughts :
- I incorrectly installed the throw out bearing
- now the entire transmission must come off again
If someone could tell me I'm wrong, I'd be a happy camper. As is, I have a third week of no daily driver. Sharing a car with the wife is getting old. Any suggestions?
My thoughts :
