Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Suspension & Armor > Off-Road 4x4 Suspensions
Notices
Reply
Thread Tools Display Modes
Old 08-25-2007, 08:17 PM   #1
brendank
It's only money...
brendank's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
brendank is on a distinguished road
Default D60 and 14b build
I've been working alot lately on my build, so I thought it was about time to post some pics.
It's a D60 from a 91 F350. I bought the whole truck as a dually for $800, took out the axle and sold it as is for $800. So the 60 was free, and the 14 bolt was $200 at the junkyard. Both have 4.10's. Scored when I found out that both also had recent brake jobs.
If people are wondering why I used a gm axle, it's because of a few reasons. The width was good, bolt pattern matched, and it's stupid strong even in stock form. Not to mention, their dirt cheap and common as a bellybutton.
I relocated the perches on the 14b to match the rear leafs on my '93. That was no problem, but I also found out that I needed to trim the gas tank skidplate a bit a bit because it was very close to the pumpkin. I'll also be adding some 6" skyjacker leafs in addition to the belltech shackles.
For the front, I'm using these brackets from ballistic fabrication. They look real nice, and I'll easily be able to modify one of them to fit on the driver's side beam between the pumpkin and the knuckle. It's pretty tight, but I should be able to make it happen by moving the upper buckets outward on the frame a bit as well. Also waiting for some Cage radius arms to tie the axle in.
I'm still undecided on the coils, but I'd like to get the brackets burned on and the rear installed so I can estimate what the ride height is going to be. The axles are staying fullwidth, and I've got a set of Bushwacker cut-outs to top it all off. Hoping to end up with somewhere around 38's.
Had to sneak a pic of the can-am in there!
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's
EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's
Fullwidth D60, Lockright, 5.38's, Dedenbear C's
14BFF, 5.38's, Detroit, Disc Braked
3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts
brendank is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 08-25-2007, 08:33 PM   #2
BDAB
BDAB's Avatar
Vehicle Year: 2014, 1984,1990
Vehicle Make: Dodge, Honda, F
Vehicle Model: Dart Rallye,V65 Magna, F150
I use this vehicle for: Dailyx2, Truck stuff
My credo: If you can't go through it or around it, then go over it.
BDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud of
Default
you aint kidding about GM axles being cheap, I just picked one up for the Suburban with 4.10's for $75............. looking for either a dodge or a GM Dana 60 with 4.10's.
good luck with your project.
__________________
The day I am forced to stand for the national anthem is the day I sit
BDAB is offline   Reply With Quote
Old 08-26-2007, 12:38 AM   #3
Cameron
Vehicle Year: 1988
Vehicle Make: Zuk + Chevy + T
Vehicle Model: Samurai buggy thing
Cameron is on a distinguished road
Default
I have the same front rad arm/coil mounts and I love them!! I think they are awesome!!
Build looks good, ready to see it on wheels.
__________________
Formerly 84farm
2003 F150 FX4 Lariat, it gets me around
1988 Samurai, getting the buggy treatment
Cameron is offline   Reply With Quote
Old 08-26-2007, 01:35 AM   #4
Mutant Pony
Mutant Pony's Avatar
Vehicle Year: 1977
Vehicle Make: Ford
Vehicle Model: Pinto
I use this vehicle for: Mud racing/trails
Mutant Pony will become famous soon enough
Default
The 14 bolt Full floater is far stronger than a 60 rear, even stronger than a 70 in my opinion. The parts are easy to get and cheap.
They are designed after a ford 9" just bigger and with a removeable cover. The pinion has three bearings which is a huge benefit.
It is also the only chevy part I won't get mad at people for using on a Ford.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 08-26-2007, 02:16 AM   #5
JohnnyU
"Outlaw"
JohnnyU's Avatar
Vehicle Year: 2008
Vehicle Make: Chevrolet
Vehicle Model: Trailblazer SS
JohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond repute
Default
I'm also using the flat bottom link/coil mounts from Ballistic.
Looks good so far.
__________________
Trail Rig (1) - 1991 Chevy Silverado - [Build Thread] (SOLD 12/2/2011)
Trail Rig (2) - 2007 Polaris Sportsman 500HO EFI
Tow Rig - 2004 Dodge Ram CTD - [Build Thread]
Earth Resin Offroad
JohnnyU is offline   Reply With Quote
Old 08-26-2007, 05:19 AM   #6
brendank
It's only money...
brendank's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Quote:
Looks good so far.
Yeah, they're sweet. Saved a ton of work. I wish I could have struck a better bead on them though. The mig has been pissing me off lately, but I found today that the ground clamp wire was all messed up. Caused it to weld really erratic and mess up right in the middle of a weld. Oh well, at least I'll be able to weld them on the axle properly.
Any suggestions for coils? I've been considering some 5.5" EB springs, but I'm not sure if that will match the rear. At this point I haven't really looked into them much though.
__________________
Old 08-26-2007, 05:40 AM   #7
hairyboxnoogle
Junior Member
hairyboxnoogle's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
hairyboxnoogle is on a distinguished road
Default
the 4.5 crawler coils from wildhorses will net about 6-7" lift, give or take when stock... or so im told.
__________________
85 Ranger: D-30 SAS + 8.8, 302 swap, and paintjob in progress
77 F-100 Ranger 460, C6, rollin on 35's, oh yeah, and stacks
65 Buick Wildcat, 390HP 445... DD for now
hairyboxnoogle is offline   Reply With Quote
Old 08-26-2007, 12:48 PM   #8
Cameron
Vehicle Year: 1988
Default
I am using 3 inch TJ coils on mine, but mine is a lot lighter as well. Same 5.5" diameter. I believe they are 180 lb/in
__________________
Formerly 84farm
Old 08-26-2007, 01:36 PM   #9
hairyboxnoogle
Junior Member
Vehicle Year: 1985
Vehicle Make: Ford
Default
the wildhorses are 200lbs per inch to 375 lbs per inch 10%. Ive heard the flex really well, and they arent too stiff... i bought a set of TJ springs 175lbs.... will flex insane probably, but theyre stupidly soft.
__________________
Old 08-26-2007, 06:28 PM   #10
Will
Super Moderator
Will's Avatar
Vehicle Year: 2007
Vehicle Make: Toyota
Vehicle Model: FJ Cruiser
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
That looks like a 3/4-ton 14-bolt, by the way. The one-ton has 3.5" wide rear brakes and the 3/4 has 2.5" wide. That's the only difference. I think a real Detroit Locker (Trac-Teck No-Spin) can be installed without changing the carrier--no gear set-up.
__________________
'83 Ranger
'07 FJ Cruiser
'09 Mazdaspeed
'14 Ninja 1000
Will is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
