Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
Notices
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 07-25-2013, 04:59 PM   #101
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger xlt
I use this vehicle for: Offroading
dhkonrad is on a distinguished road
Default
Got started on radius arms.
Cut the old one down a bit
ground down a bit of the inside part of the ribs so that the tube would slide in.
and as commonly is done, slit down the center of the tube and slid the DOM over the end of the radius arm
gave a bit of radius and curvature on the end of the DOM to get it to sit cleanly on the wedge, and then tacked it up.
Tires only a 35, so you can see they aren't SUPER long.
Under the truck
Now I just need to do the other side, cycle it one more time, and then tack weld the link mounts and set it on the springs so I can get an idea of ride height.
When I go to weld the DOM to the old radius arm, should I stick weld it with 7018 because of the the Radius arm, or will I be safe to MIG weld it?
dhkonrad is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 07-26-2013, 02:21 PM   #102
2004xlmiller
March 2013 OTOTM Winner
2004xlmiller's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
2004xlmiller will become famous soon enough2004xlmiller will become famous soon enough
Default
Really like how this is turning out!
__________________
2004 Ranger 3.0 5 speed
Hurst, BTF 5.5 kit, 32s, lots of other crap.
http://www.therangerstation.com/foru...d.php?t=114632
2004xlmiller is offline   Reply With Quote
Old 07-26-2013, 02:26 PM   #103
brinker88
11/2013 OTOM Winner
brinker88's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Weekend Warrior
brinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to behold
Default
Quote:
Preheat the radius arm and mig it. Then wrap it in a heat blanket to slowly cool it.
__________________
Obsession is a word justifying your insanity. We ARE the 4x4%.
Apple Hill 4x4
brinker88 is offline   Reply With Quote
Old 07-27-2013, 12:10 PM   #104
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Quote:
Thanks man! I feel like I am starting to be able to see the light at the end of the tunnel!
Quote:
Sounds like a plan.
Got the second radius arm tacked up and on
I moved the frame side trackbar mount forward because I was worried about it interfering with the coil and it helped give clearance for the diff/trackbar
it does contact the tie rod now, but oh well. I can always move the axle forward a little bit, but truthfully, I don't think there is anyway on this earth I am going to get the axle to suff that hard, nor am I going to get TREs to articulate that much at the pitman arm... So I am pretty happy with those clearances.
and radius arm clearance
Yes thats my old radius arm mount still welded to the frame. Im kinda lazy...
Old 07-27-2013, 02:38 PM   #105
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Full bump on passenger side
limiting factor is engine crossmember (surprise surprise), and tranny cross member. I trimmed the crossmember a bit already, but looks like I will have to do more...
full bump for both sides
and clearances
Old 07-27-2013, 10:25 PM   #106
2004xlmiller
Vehicle Year: 2004
Vehicle Make: Ford
Default
Sick! Almost there!
__________________
Old 07-28-2013, 11:16 AM   #107
stiluv
01/2014 OTOTM Winner
stiluv's Avatar
Vehicle Year: 1999
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: picking up your mom, taking her out and never calling her again
stiluv is on a distinguished road
Default
im diggin the c bushings.
stiluv is offline   Reply With Quote
Old 07-29-2013, 05:08 AM   #108
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Sick! Almost there!
Thanks! Getting close enough to taste! Just keep running into bunches of small stuff...
Quote:
You talking the radius arm ones? Those are specially designed adjustable ones
Old 07-30-2013, 12:54 AM   #109
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Way out of practice on my TIG...
Got alot better as I did a few...
trackbar welded up
Got it on its own weight. Kinda. Just jacks under the axle, but full weight on the springs none-the-less.
Drivers side spring has some spring bow, but not terrible. It will be even better with true wedge bushings in so it doesn't allow the radius arm and lower coil bucket to rotate
Passenger is terrible... that's even with a shim under the front of the coil
So my question is this. Passenger side coil bucket is super easy to move, while the drivers side would be less so. It is also my passenger side coil that has lots of bow, and would benefit most from having the bucket moved. Would it be terrible to move only one side? I don't see why it would, but...
Old 07-30-2013, 12:56 AM   #110
dhkonrad
2013 Offroad TOTY
dhkonrad's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Oh and if anyone was wondering, the Wildhorse 5.5 rock crawler springs were about 17.5" with full weight on them. But that is un-broken in too.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
