Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Ford Bronco II's
Notices
Ford Bronco II's Be sure to check out the Bronco II Corral!
Reply
Thread Tools Display Modes
Old 08-19-2013, 09:42 AM   #1
Catterman
Junior Member
Catterman's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Collector
Catterman is on a distinguished road
Default I keep blowing turn signal fuses! HELP!
1990 B2, I even thought it was something with the switch, but I swaped that out and I still keep poping that 15amp fuse for the turn signals. Any idea what I should check next? Thanks!
Catterman is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-19-2013, 10:08 AM   #2
RonD
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Does fuse blow with key off?
Does fuse blow only when one side is selected? i.e. left or right turn signals
Instead of a fuse I would use a 12v test light in place of the fuse, it will be bright because of the short and then get dim or go out when you find it and lift it.
here is a wiring diagram:
http://www.therangerstation.com/tech...top_hazard.JPG
One thing to check is a trailer connection, even if you never used it, these do get corroded and will short out the system.
RonD is online now   Reply With Quote
Old 08-20-2013, 09:28 AM   #3
Catterman
Junior Member
Catterman's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Default
I will try and test it out today, thanks for the help.
Old 10-09-2013, 08:51 AM   #4
Catterman
Junior Member
Catterman's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Default
Okay, just got into this again...
The turn signals work if I have the key in run, but once I start it up they pop. I checked out the wireing diagram but I am not very good at reading that kind of stuff, so... From what I gathered I should next check
1) trailer lights (not sure if I have any?)
2)turn signal flasher - could this go bad and cause the fuses to pop?
Anything else I am overlooking? Thanks.
Old 10-09-2013, 01:11 PM   #5
PetesPonies
Vehicle Year: 1983
Vehicle Make: Ranger
I use this vehicle for: making an '83 Ranger seem even older
PetesPonies has a spectacular aura aboutPetesPonies has a spectacular aura about
Default
A blown fuse in 99% of the cases, is a short. Meaning, there is a place where bare wire is touching something it shouldn't be touching, thus allowing more electricity to flow than the fuse allows. Hence, blown fuse.
__________________
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 10-10-2013, 11:17 AM   #6
Catterman
Junior Member
Catterman's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Default
Do you think it would be between the fuse box and steering wheel? Or by each light?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
