Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 05-12-2008, 12:30 AM   #1
smittylopez
smittylopez is on a distinguished road
Default removing rear 8.8 axles
I saw in the removing axle seal insert on the Tech library that the pinion shaft needs to be removed to pull the axles. Is this the actual pinion gear (which includes removing the drive shaft) or something else? I am going to be digging in this tommorow some time.
smittylopez is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 05-12-2008, 03:01 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
To remove the axles on your 8.8 you have to jack up the rear end so the tires are off the ground. Remove both tires and the brake drums. Remove your rear diff cover and drain the fluid out of the diff. There will be a cross shaft in the carrier case that holds the spider gears in, there will be a 5/16" bolt that holds the cross pin in. Be careful if you have to use a 12 point wrench to remove it as it can be very tight and you will round the head off. The best bet is to use a 6 point wrench or a 6 point socket if you can get one in there. Once you remove the bolt you will be able to tap the cross shaft out of the carrier. Once it is removed grab the axle shaft at the flange with the wheels studs on it and push it in till it bottoms out, remove the c clip that holds it on in the diff and pull the axle shaft out of the housing once you have the clip removed. Repeat for the other side. Remove the old seals, install the new ones and reassemble in the reverse order.
Good luck.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 05-12-2008, 06:06 PM   #3
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
To answer your question about the pinion shaft, it's actually refered to as many names, cross pin, cross shaft, ect, it's the shaft that the spider gears rotate on and it prevents the axes shafts from moving inwards and the c-clips from falling off.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
