Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Engine Conversions > 'Other' Engine Conversions
Notices
'Other' Engine Conversions All other engine swaps. Not for discussing V-8 swaps
Reply
Thread Tools Display Modes
Old 06-30-2008, 12:11 PM   #1
Sevensecondsuv
Sevensecondsuv's Avatar
Vehicle Year: Many
Vehicle Make: All Fords!
Vehicle Model: Most of what Ford Made in the 90s!
I use this vehicle for: Life
Sevensecondsuv is on a distinguished road
Default 300 straight six - do they make stroker cranks?
So I've been planning my next build. It's going to be a 80-86 F-350 4x4. This will be my "truck" for the next several years. It won't be driven daily, just used to haul things.
Anyways, I'm trying to decide on an engine. I don't like convention, therefore a 351, 351 stroker, diesel, and other popular options are out. I like the stroked 460's, but my friend has one in an 87 F-350 so I'd like to do something different. Not to mention that thing is THIRSTY!
So this had led me to the 300. I've always liked the 300 for it's impressive durability and low-end torque to pull anything you can hitch up to it (just maybe not very fast). But a stock 300 just aint gonna be enough for the truck I'm planning.
I've done some research and found that 10:1 compression, port and polish, mild cam, full intake and exhaust mods, larger valves, 600 cfm carb, etc will yield 300 HP at about 4500 and 400 TQ at 3200 (as proven on a dyno). That's enough, but I'd like some more torque. That's where the idea of stroker hit me. That engine at 360 cubes would be a torque monster and would be what I want.
So, does anyone know if they make stroker cranks for the 300 and where can I find them?
__________________
2011 Ford Ranger 2.3 5-spd; 2001 Ford Ranger 2.3T Lima 5-spd;
1992 Explorer 4wd 5-spd; 2000 Ford Excursion 6.8 4wd;
1995 Ford F-250 4wd 4.9 ZF-5 D60 SAS;
Past: 1990 Ranger 2.3 Turbo
Sevensecondsuv is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 06-30-2008, 12:32 PM   #2
Captain Ledd
Captain Ledd's Avatar
Vehicle Year: 1984, 1997
Vehicle Make: Ford
Vehicle Model: Rangers
I use this vehicle for: Literally everything.
My credo: If you're not making mistakes, you're not learning.
Captain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to allCaptain Ledd is a name known to all
Default
the 300 already has a stroke of 3.98". If you manage to find the forged steel crank (good luck) you can have it welded and ground back out to I think 4.375, which is something like 338ish cubes IIRC. Some company used to make them years back but has since stopped. I've heard the bearings went out much much faster.
The better option is probably a turbo. Turbo's are nice because they only make extra power (i.e. boost) when you're on the throttle, so otherwise they run and use as much fuel (for the most part) as the standard engine. A modern turbo that is correctly sized has darn near instant spool time and lag is almost a non-issue (there's other things that can influence it though).
Also another thing, try here: http://fordsix.com/forum/
TONS of info on the 300 sixes specifically, and the guy running the site is developing an aluminum cylinder head for the 300 six. He's already got one out for the 170/200/250 inline sixes Ford had in the early Mustangs and Mavericks, etc. and it turned out amazing.
http://www.classicinlines.com/
Captain Ledd is offline   Reply With Quote
Old 06-30-2008, 06:07 PM   #3
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
Yeah, a turbocharged 300 six would be "neat"
Though it may seem "odd" I'd actually recommend using TWO turbochargers
One off each batch of three cylinders.
The reason for this is that most common turbochargers are designed for engines approximatly half as big
I'd limit boost to 5-6lbs unless you manage to find forged pistons for the engine.
6lbs of boost into a 4.9 and you'd better have the big ZF trans behind it, because
on the boost it's going to make the transmission think there's a 460 V8 up front.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 06-30-2008, 10:08 PM   #4
Sevensecondsuv
Vehicle Year: Many
Default
ZF-5 is what I was planning. I own (and built) a turbocharged Ranger. It's a lot of fun and very fast, but I wouldn't want it in a big truck, that's why I was wanting to stay naturally aspirated.
I'm not afraid of machining a stock crank, putting larger bore sleeves in, using rods and pistons from whatever (even chebby, gasp!) etc. Keep the ideas coming!
__________________
Old 07-01-2008, 02:23 PM   #5
Captain Ledd
Vehicle Make: Ford
Default
Not to tell you how to build your project, but as a NA engine, the 300 six.. well.. it don't make alot of power, just low end torque.
The stock cylinder head needs a LOAD of work and machining to just make it adequate for the 300 cubes that it is, let alone larger still.
But otherwise to throw some things your way about the 300:
Headers
LOTS of porting
bigger valves, but not tooo big
make sure they're unshrowded ^
a really good camshaft, 260-270 durationish which should keep the RPM's low enough for streetability. (were still talking never more than 5000 rpm's here)
Bigger injectors and throttle body (or carb)
cast iron cranks really don't care to be welded on unless by a super qualified professional.
DUI ignition or some other kind of super high energy system
I'd keep the CR down to 9.5 or so.
I don't know if the block can take a much larger piston to make it worth it, even if sleeved.
Until the Classic inlines aluminum head is released, I really feel that's about what you're gonna find in terms of power additions. Except for spray or forced induction.
Now, I have heard that 351C heads can be cut apart and furnace brazed back together and stuck on a 300 block, some drag racing Maverick had those on it. And supposedly GM LS1 and LS7 heads have the same bolt pattern as the 300 six (completely unverified) and can also be cut up and furnace brazed back together. But your left with custom intake and exhaust. Food for thought.
Pretty much no one except for Clifford Performance and Classic Inlines makes anything for the 300 six. Other than that your on your own in the quest for more power.
Old 07-01-2008, 04:36 PM   #6
Sevensecondsuv
Vehicle Year: Many
Default
I might be open to doing 13:1 compression with ethanol and water injection. I'm just trying to stay non-turbo and six cylinders.
I don't really care about HP so long as it's enough to keep up with traffic. I want a torque peak of 500 ft-lbs at or below 3000 RPM though.
I did some research and found a company that will make a custom crankshaft with a 4.75" stroke for any application it will fit in.
I figured if I had the custom 4.75" stroke crank made along with a 0.100" overbore (sleeves?) and 1" deck spacer (to keep the stroke/rod ratio high enough) it would net me 376 cubes, which I think would do it with high enough compression, and right carb and cam.
As for the head, I'm no stranger to porting. I opened up the exhaust ports in my 2.3 from 1.25" diameter to 1.75" diameter. I had it bench flowed and it did 65% over stock on both intake and exhaust. I'd be willing to do this to a 300 head. The other thing is that this project is still a few years off so maybe the classic inline's head will be out by then. I'd want to know it will make good low end torque before I went that route.
__________________
Old 07-06-2008, 01:54 PM   #7
AllanD
Vehicle Make: Ford
Default
500ft/lb?
From a 4.9?
Not gonna happen without forced induction.
AD
__________________
Old 07-06-2008, 02:33 PM   #8
Will
Super Moderator
Will's Avatar
Vehicle Year: 2007
Vehicle Make: Toyota
Vehicle Model: FJ Cruiser
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
Stroke means nothing when you are talking torque. I know lots of people think it does. The only important thing is how much fuel you can burn in a single combustion. Stroke doesn't help that, only displacement and airflow efficiency matters on a naturally aspirated gas motor.
What stroke does do is increase the airspeed at lower rpms, which helps fill the cylinder more quickly at low engine speeds. That's great for a truck motor like a 300-6, or a 5.4 or a 6.8. Stroke is not about leverage, it's about controlling piston speed. Most of the push of the piston is done near the top of the combustion chamber. A short stroke with a long rod would be the best at getting good leverage on the crank.
A stroker kit is good for adding displacement when you are out of room to overbore.
The 4.6 in the 2009 Mustang makes 1.14 ft# per cubic inch--as installed in the car. If you are going to take a 40 year-old technology and think you can come close to that, you are greatly mistaken. And that would only be 340ft#. The best the fuel injected 300 did was .88ft# per inch as installed, and the carbed ones were around .75 per inch.
__________________
'83 Ranger
'07 FJ Cruiser
'09 Mazdaspeed
'14 Ninja 1000
Will is offline   Reply With Quote
Old 07-06-2008, 08:13 PM   #9
Captain Ledd
Vehicle Make: Ford
Default
Quote:
Originally Posted by AllanD View Post
500ft/lb?
From a 4.9?
AD
Thats about what I was thinking. He was pretty set on getting creative with N/A, and I figured "who knows" (I've messed around with alot, but I don't know everything.). I was kind of curious to see what he came up with.
Old 07-06-2008, 11:14 PM   #10
AllanD
Vehicle Make: Ford
Default
Frankly 500ft/lb is above what a 7.5EFI can do without modifying it from stock.
On the other hand if he decided to go turbocharged I doubt he'd need
more than 7 or 8psi of manifold pressure.
Not only that but if he did something completely silly, like drive to Denver
or Cheyenne, he'd experience NO loss of performance with his increase
in altitude, because a pair of T-03's would EASILY be able to maintain 8psi even
going over Loveland pass (~12,000ft)
His "modified" engine? He's going to take a relatively efficient engine
and essentially ruin it for fuel economy by making it a stroke monster.
while turbocharged it would still get the same economy in "cruise"
and an inline engine is EASY to turbocharge....
AD
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
