Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Ford Bronco II's
Notices
Ford Bronco II's Be sure to check out the Bronco II Corral!
Reply
Thread Tools Display Modes
Old 01-22-2009, 04:33 PM   #1
97fordrunner
97fordrunner's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Weekend Wheeler
97fordrunner will become famous soon enough
Default A4LD filler tube removal
Hey fellow BII'ers I posted over on TRS but thought I would throw it your way to, I have the tranny 99% free of the chassie but am stuck on the filler tube, does it press in like the service manuals show or does it have a snap ring inside the tranny pan that holds it from poping out? thanks fellas
97fordrunner is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 01-22-2009, 04:50 PM   #2
fordmandan87
fordmandan87's Avatar
Vehicle Year: 87/92/97/11
Vehicle Make: Ford×3/Freightl
Vehicle Model: Crown Vic/Explorer/F-250/Cascadia
I use this vehicle for: Everything it was not designed to do/DD
fordmandan87 is just really nicefordmandan87 is just really nicefordmandan87 is just really nicefordmandan87 is just really nice
Default
no, slides out when unbolted from tranny near top
fordmandan87 is offline   Reply With Quote
Old 01-22-2009, 04:52 PM   #3
Flat Toy
Flat Toy's Avatar
Vehicle Year: 1986/1998
Vehicle Make: Ford
Vehicle Model: Bronco II/Ranger
I use this vehicle for: DD/DD
Flat Toy is just really niceFlat Toy is just really niceFlat Toy is just really niceFlat Toy is just really nice
Default
It presses in but it is bolted to the engine also. That bolt has to be removed to pull the tube out.
Flat Toy is offline   Reply With Quote
Old 01-22-2009, 04:55 PM   #4
97fordrunner
Vehicle Year: 1997
Vehicle Make: Ford
Default
Ok thanks guys I'll get that taken care of, thanks for the quick response
Old 01-22-2009, 08:27 PM   #5
snoopdoggie
Vehicle Year: 1988,89,89,94,9
Vehicle Make: Ford
Vehicle Model: Ranger Bronco II Ranger Ext. Explorer Explorer EB
I use this vehicle for: Daily Driving
snoopdoggie is on a distinguished road
Default
Every tube I have seen is two piece. The lower piece just pushes into the trans housing. The upper piece uses one of the trans to block bolts to hold it. At the joint of the two pieces, which is just a push in fit, there is an o-ring.
snoopdoggie is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
