Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Notices
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 02-08-2009, 08:24 PM   #1
fishon91
Junior Member
fishon91 is on a distinguished road
Default engine temp gauge not working
after a loooooong job of replacing the motor , i cant believe how little is still not right. my check engine light is on, of course, advanced aouto parts told me it was the engine temp guage and the intake manifold was tuck open. i've been driving it all day, and it runs fine. im thinkin if i get this gauge fixed the light'll turn off.
any way, im pretty positive i found the right sensor, it's plugged in to the block fine and goes right in with other wires, that are all wrapped up. all the other gauges work. might need a new sensor but i wnated to see if any of yall had previous expieriences bafor i do it. i might need to take off the intake in order to get a wrench on it.
fishon91 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 02-08-2009, 09:41 PM   #2
shadetree
shadetree's Avatar
Vehicle Year: 1994
Vehicle Make: Explorer Sport
I use this vehicle for: Work
shadetree is on a distinguished road
Default
What year? What engine? Temperature gauge has nothing to do with CEL. Cel is for emissions related equipment.shady
shadetree is offline   Reply With Quote
Old 02-08-2009, 11:00 PM   #3
fishon91
Junior Member
Default
2003 ford ranger 2.3 liter. the guys at advanced hooked up their thing that chechs why your CEL is on, and thats of the reason it was on.
Old 02-17-2009, 09:31 AM   #4
bro2
bro2's Avatar
Vehicle Year: 1986
Vehicle Make: ford
Vehicle Model: bronco II
I use this vehicle for: wheeling and street drivin
bro2 is on a distinguished road
Default
If your getting a cel your coolant temps sensor is bad ,not your temp guage sender . The easy way to find the sensor is to look at the replacement and find the one that looks like it (if you get the right part ). The temp sender is usualy on the intake and has 2 or more wires. This part can cause hard start hot or cold ,poor performance ,bad fuel mileage.
__________________
86 bronco II 93 4.0 liter 4inch rough country suspension lift,3inch body lift ,manual t-case,pro comp mt 33 12.50 ,dana 35 with loc rite locker and 4.10gears,7.5 rear with possi and 4.10
bro2 is offline   Reply With Quote
Old 02-21-2009, 12:10 PM   #5
fishon91
Junior Member
Default
well the only thing that seems to be weird is that while the engine is idling i can tap the gas and the RPM's will move up even while my foot is not on the pedal, and the once to about 2,100 RPM's it falls back down to a slightly high idle. which seems like the intake manifold being stuck open. maybe run some carb clenaer through it, and see how it runs then.
i thought i had founs the sensor on the driver side of the block, but then bought a coolant t emp sensor, which is what they told me i needed, and it was a different thing. couldn't find the same thing they gave me, and returned.
Old 02-21-2009, 12:12 PM   #6
fishon91
Junior Member
Default
ok im sorry bro i read your post wrong. so i just need to find out where the sensor is located.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
