Fix it or Junk it?
akulczycky
I've got a 1997 Ford Ranger XLT 2WD 2.3L with ~130k on it. I got the car as a hand me down from an uncle a year ago with 100k on it, so the repair/ maintenance history is somewhat unclear.
Recently the brake lines heading to the front brakes from the master cylinder sprang a leak. After trying to fix it myself, I realized I didn't have the tools to do it, and brought it in to a shop for an estimate on the repair cost. In doing so, the shop discovered (and I had them point it out to me) that not only the front brake lines needed replacing, but essentially the entire brake system, excluding the master cylinder, needs replacing (Front and rear brake assemblies, the hoses, lines). Additionally, one of the leaf springs is broken, the parking break cable needs to be replaced, and I need to replace the heat shield over the muffler, in addition to some "minor" repairs that are not urgent.
The mechanic told me that the cost would be in excess of $2000 to repair - leading him to suggest junking it. The frame is solid, I have only very minor rust forming.
After pricing out the parts, I'm somewhere in the $500 - $600 range, with potential for a lower cost if I go junkyard diving.
I'm considering trying to repair it myself, but I have limited experience, but lots of time (currently unemployed). I'm looking for opinions as to whether or not you would recommend an amature to undertake such an overhaul, and whether or not it would be something that is safe for me to do, or if I should simply junk the car.
If I junk it, I'll be able to afford another car in the near future (Hopefully being selected as a navy nuke and I'll get the selection bonus), but if it's just a heavy time investment and I'd be able to fix it, I'd rather not have to "invest" in a new car.
Your opinions, experiences, and advice will be greatly appreciated in deciding what I should do here. Thanks!
michowski
2
Fix it up yourself. There is no better feeling then taking something broken and need of some fixing up and making it work again. You will not only have a running vehicle but you will also have gained a lot of knowledge on how to work on your truck as well. We got this great site here with an awesome tech library and the forums so any questions you have will be answered.
Fast Doc
2
That question is easy. Fix it yourself. New calipers, maybe have the rotors ground, some brake lines, a few details and you're good to go. Less than $300 I'd bet. Some busted knuckles and cursing and you're done.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
$2000? That's rediculous.
For $2000 you could not only buy the tools and materials
but take a shop course and learn how to do it yourself.
BUY a flaring tool
Likely you can "Get by" just replacing the rigid lines, for now anyway...
Muffler heat shield? Why? so the bed floor paint doesn't discolor?
Remember a "shop" is concerned about liability particularly on stuff like brakes.
While most traffic accidents are caused by "pilot error",
of those that are caused by mechanical failure the vast majority
(>9 of 10) are cause by some sort of brake system malfunction
So shops tend to "overreact"
If you don't want to do it over you CAN get stainless steel rigid line
(Summit sells the raw line) and make the lines from stainless steel
and NEVER replace them again...
AD
kunar
Forum Staff Member
131
Toledo, Ohio
Engine Type
V8
5.8l
2WD / 4WD
2WD
fix it... always fix it. theres not a damn thing that could go wrong with my truck that would cause me to junk it. okay maybe if i rolled it down a hill or something but you get the idea...
Colin
182
ON Canada
Mazda
Engine Type
2WD / 4WD
2WD
Fix it, you can always post any questions on the forum.
DRanger024
Solid Axle Swap
Ham Radio Operator
GMRS Radio License
482
Dale, WI
Ranger
Engine Type
2WD / 4WD
Solid Axle Swap 4x4
6-7” front maybe 3” rear
Total Drop
33x12.50-15
This kinda fits in with the old saying "if it aint broke, dont fix it". If your other lines are still holding fluid then dont bother. If your front calipers and rear drums still operate correctly dont replace them, put new wear items in and its all good. What did he say was wrong with the parking brake cable? And muffler heat shield? I take them rattling pieces of crap off of every vehicle i've ever owned. Never had a problem to date.
akulczycky
I told the guy to write everything down when I get the car back, so I have a record of it, but the other lines are going, and one of the rear is leaking, I figure, if I'm gonna do two, and I have the time, might as well do all of them, and fix up anything else.
There are a few other things he mentioned, one of the leaf springs, potentially some transmission thing (he didn't look at it, but the clutch was sticking on me earlier), and something with the rear differential.
I think the consensus is have at it, have some fun, even if it takes twice as long as a mechanic, I'll learn something in the process. I think between the manual I got and the resources on the website, I'll go wild.
DRanger024
Solid Axle Swap
Ham Radio Operator
GMRS Radio License
482
Dale, WI
Ranger
Engine Type
2WD / 4WD
Solid Axle Swap 4x4
Total Drop
33x12.50-15
Junk yard for the broken leaf. Check the fluid level on the clutch resevoir as it may be low causing the clutch to stick. Rear dif could just be leaking a little bit but thats easily fixed with a new seal. It sounds like you have multiple minor things that are making it seem like you have a few major problems.
gertsdsbs
On the Moon
2.9 v6
Kill it, Kill it omg I can't look. lol FIX THE DAMN THING.
akulczycky
Okay, I picked it up, it's in my garage, here's the "what's wrong report" and what he did.
"Comprehensive brake system inspection"
Removal of 4 wheels, master cylinder inspection, brake lines, hoses, calipers, and wheel cylinders, etc.
-Front Brakes 4-7/32" of padwear - pads grooved - rotors chunked and peeling.
-Rear Brakes - Shoes cracked and falling apart - drums no good.
-Parking Brake - Rear Emergency Cables seized (R/R seized - L/R Binds)
*Recommended
1. All brake lines
2. Front brake hoses
3. front pads and rotors with seals, repack wheel bearings due to type of rotor.
4. Rear wheel cylinders, shoes hardware, drums, adjuster kits,
5. axle seals - right rear blown.
6. Rear differential cover severely rusted.
7. Rear pinion seal leaking
8. Replace fuel tank straps
9. Left rear leaf spring broken.
Gonna tackle the brake lines first (b/c the front 2 are broken)
Beef52751
13
Eastern Iowa
2.9
Sounds like about a weekends of work and it'll be just fine.
Duke
Rockbridge, WI
4.0
Your truck only has 130,000, so its life isn't even half over. That thing has many miles left in it. It may seem intimidating at first, but it is a matter of taking the old stuff out and putting the new stuff in its place. It may take you a while the first time, but it will be rewarding and you will soon graduate to doing more advanced fixes on your truck. Just take your time and stay organized when you do it. I agree with Fast Doc that it should be under $300.
When working on your truck there are some things you can buy on ebay that will really save you some cash too.:icon_thumby:
pyrosity
WASHINGTON
FORD/FORD
3.0/5.0L
yah man ide fix it. If your lucky ide check your local craigslist and start looking for someone else who has a beater or totalled junk car that they want to get rid of...... lucky for you i happen to be getting a newer junker to replace all my broken stuff and might have alot of that stuff left over, give yah a deal you cant refuse..... I should have breaklines. calipers, stock leafs(for a 4x4 not sure if those will fit). and the rusted diff cover is a quick fix...nothing like a quick 30$ schucks wire wheel grinder and an hours time of work. and some red paint to make her look all new.....
LET ME KNOW WHERE YOU LIVE AND MAYBE WE CAN GET TOGETHER....IM IN WASHINGTON.
Staff online
Shran
April Truck of The Month
