Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Reply
Thread Tools Display Modes
Old 08-29-2009, 12:21 AM   #1
Chris Bowles
Vehicle Year: 1999
Vehicle Make: Ford Ranger
Vehicle Model: Ranger 3.0 v6
Chris Bowles is on a distinguished road
Default Ford ranger cold start problem??
when i start my ranger it cranks for like 5 seconds befor it starts and when it does start it like sputters then firers. but it doesnt do it really when its warmed up. like itll start right up when its warm. any one have an i dea of wehat it is. i was thinking maybe a new starter, or spark plugs and wires???? any input on this?
Chris Bowles is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-29-2009, 01:26 AM   #2
mattpresley
mattpresley's Avatar
Vehicle Year: 2006
Vehicle Make: FORD
Vehicle Model: F150 Longbed
I use this vehicle for: DD, Hauler, Work truck
My credo: WTF is credo?
mattpresley will become famous soon enough
Default
Quote:
what do you mean by sputters and fires? what I start mine cold it shakes til it warms up but only sometimes
__________________
Check out my truck's thread click here
mattpresley is offline   Reply With Quote
Old 08-29-2009, 01:28 AM   #3
4byRANGER
4byRANGER's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: eveyrhting !!
4byRANGER is on a distinguished road
Default
maybe your fuel filter needs to be changed?
__________________
1995 ford ranger ext cab, swapped 4x4 and auto for 2wd and 5 speed!!
4byRANGER is offline   Reply With Quote
Old 08-29-2009, 03:03 AM   #4
Chris Bowles
Vehicle Year: 1999
Default
i recently changed the fuel filter. and by sputter and fire up i mean like ill turn the keyy and it takes a while then when it does start it starts but like is in low rpm and sputters a little bit then idles at normal rate and runs fine
Old 08-29-2009, 11:08 AM   #5
Big Jim M
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger FX-4 level 2
I use this vehicle for: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
Try turning the key to the run position for 5 or 10 seconds to get the fuel pump to build up pressure before starting the engine. It is common for older vehicles to lose fuel pressure overnight. The fuel leaks backward into the fuel tank after a few hours.
Big JIm
Big Jim M is offline   Reply With Quote
Old 08-29-2009, 09:13 PM   #6
Anger Ranger
Anger Ranger's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: Topless Hearse
Anger Ranger is on a distinguished road
Default
I had a problem like that with the Ignition coils once I had a VW. When it rained, the car hesitated, and smelled like gas. Check engine lights, rough idling and low rpms. Everything was like that until.......it warmed up.......I tried many things but then I thought they were the ignition coils because in other forums people had the same exact problems. You might get a new ignition coil or the "epoxy" solution, or warm up your truck earlier when it had rained overnight.
In other words, moist gets inside the coils and cause a misfire and then a "check engine light". When your car warms up, the heat evaporated the moist trapped inside.
For reference google this: "epoxy solution ignition coils jetta", you will be surprised that a lot of people had this problem.
Hope it helped you a bit.
Anger Ranger is offline   Reply With Quote
Old 05-29-2013, 08:17 PM   #7
swascott1981
Vehicle Year: 1999
Vehicle Make: Ford
swascott1981 is on a distinguished road
Default
Yea I have the same problem I'll turn it over it sputters real bad then I'll cut it off and crank it again and its fine anyone know y it does that
swascott1981 is offline   Reply With Quote
Old 05-29-2013, 08:20 PM   #8
UrbanRedneckKid
UrbanRedneckKid's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Taking all my time and money
UrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the roughUrbanRedneckKid is a jewel in the rough
Default
Hook a scan tool up to it, see what the CTS (coolant temp sensor) reads.
Start there.
__________________
94 Ranger, just slightly modified.... Trailer queen
99 Explorer, EB package, 5.0
88 Ranger, 4/6 drop, 93 powertrain/ dash swap
http://www.therangerstation.com/foru...ad.php?t=33396
UrbanRedneckKid is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
from old 4.0 swap MrE_Powers 'Other' Engine Conversions 5 04-26-2011 08:59 PM
Chevy V8 into Ford Options jmkjr72 V-8 Conversion Forums 4 11-16-2009 01:55 AM
Cold start stumble problem maddyn 4.0 Liter Forum 7 04-22-2009 09:21 AM
94 ford ranger starting problem drifter 4.0 Liter Forum 4 03-22-2009 06:17 PM
Truck won't start in cold weather Ranger22 3.0 Liter Forum 7 12-17-2008 03:34 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
