Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
Notices
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 09-17-2009, 09:54 PM   #1
Brutal6
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Broncoii
Brutal6 is on a distinguished road
Default Recommend fuel pressure regulator
Just installed an electric fuel pump on my 2.8 engine and can't get a good idle. What type, size, etc., fpr do you recommend and what should the fp be set at.
Thanks,
B6
Brutal6 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 09-19-2009, 11:33 AM   #2
OilPatch197
OilPatch197's Avatar
Vehicle Year: 1984/87
Vehicle Make: Ranger
OilPatch197 is on a distinguished road
Default
It's fairly low, 4 psi I believe, somewhere around there... when I had a Electric fuel pump on my truck (didn't have the TIME and "engineering" to replace the defective mechanical unit- a royal pain to remove, I've done it twice!!)
I used a Solid state pump, self priming and they "tick" all the time. I had NO idling problems what-so-ever. It was designed for carbed motors.(no reg required)
OilPatch197 is offline   Reply With Quote
Old 09-20-2009, 09:50 PM   #3
Brutal6
Vehicle Year: 1985
Vehicle Make: Ford
Default
Thanks for the reply OilPatch, I do appreciate.
B6
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
from old 4.0 swap MrE_Powers 'Other' Engine Conversions 5 04-26-2011 08:59 PM
Fuel Pressure Regulator farfromsane Forced Induction 0 08-04-2009 08:46 PM
Strange fuel pressure behavior sevynos 2.9 Liter Forum 12 08-04-2009 01:28 PM
Fuel pressure regulator leaking gas ront 2.9 Liter Forum 2 07-19-2008 11:09 PM
Another tuning question...fuel pressure, carbs and jetting Dan B. V-8 Conversion Forums 7 04-28-2008 08:14 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
