Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
Notices
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 03-20-2010, 09:28 PM   #1
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
escort_gts's Avatar
Vehicle Year: 1993, 2001
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Daily Driver
escort_gts is a jewel in the roughescort_gts is a jewel in the roughescort_gts is a jewel in the rough
Default 89 ranger SAS build
Well I have saved and collected stuff for a year or so and I am finally starting the swap.
The truck was originally a 2wd. My brother and I swapped a Dana 28 and 7.5 out of his Bronco2 that he totaled. It was already geared to 4.56. So I also cut out the engine crossmember and replaced the 2wd one in the ranger. That wasn't fun. More than I expected.
Well after three years after the conversion the Dana28 blew up one winter when I ran into snow filled ditch and tried to get out on my own. So trying
to find another d28 diff and 4.56 gears was not easy. So I decided to do a sas on the ranger.
I got a dana30 out of a 92 xj that I had years ago that I took the the front and rear axles out of and had them sitting in my parents shed.
This is what it looked like after sitting in the shed for years.
I cleaned it up. sandblasted it and painted it. Had to re-gear it to 4.56 as to be the same as the rear.
I will be posting pics as I go and try to keep updates.
escort_gts is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 03-26-2010, 10:01 PM   #2
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Update... I got control arms from IronMan4x4 Fab and link brackets from Ballistic Fabrication. I just ordered coil springs from Bronco Graveyard, they are the 73-79 Bronco/F150 4" Superflex. Trackbar from Rugged Ridge.
I ordered some tires from where i work for dirt cheap. 35x12.5 15 for $50 each new. Had some rims sitting around in boxes that never used.
I got these shock brackets from a buddy that didn't like them so he gave them to me that I will use.
Old 04-02-2010, 10:03 PM   #3
kroussinoffroad
October 2011 OTOTM Winner
kroussinoffroad's Avatar
Vehicle Year: 2000
Vehicle Make: Ferd
Vehicle Model: f150
I use this vehicle for: Hauling Trash
kroussinoffroad is a jewel in the roughkroussinoffroad is a jewel in the roughkroussinoffroad is a jewel in the rough
Default
the build is lookin good. how are the iron long arm's?
kroussinoffroad is offline   Reply With Quote
Old 04-02-2010, 10:22 PM   #4
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
got the dana 30 under today. its sitting on the springs and having problems with the steering. The Iron Man arms are cool. They adjust easy. They are heavy, 40lbs each.
Got a set of 63's from a local yard for $50 along with Beltech 6400 shackles for the rear.
I have taken pictures and when I get time will post some.
Old 04-02-2010, 10:24 PM   #5
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Hope the coil springs will settle some. It's almost too high.
Old 04-02-2010, 10:43 PM   #6
kroussinoffroad
Vehicle Year: 2000
Vehicle Make: Ferd
Vehicle Model: f150
Default
i'm in the same boat with the front springs and i went with the 5.5"ers
once i saw the jeep steering on the front of my truck it became pretty evident that there was NO option of runnin it and making it work.
I kinda like how adjustable the iron man arm's look quite a bit more than the rusty's. do you have the 35's mounted on the truck yet ? any clerance issue's?
Old 04-02-2010, 10:48 PM   #7
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
the 35's are on with the weight on them. I might not have any clearance issues, but I won't really know till i get more done. I know that with the weight on the coils they are 20 1/2" compressed. I wanted them to sit around 19-20" but close enough for me.
Old 04-03-2010, 08:46 PM   #8
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
started working on the rear today, leave the steering for later. Removed the bed, cut the front hanger off on the driver side, the hardest. Went through 4 drill bits trying to drill one hole The 63's i got I have to torch the hangers, bolts and bushing cause they are rusted and can't get them apart . I will work on it some more tomorrow and try to get the pictures uploaded soon.
Old 04-03-2010, 08:58 PM   #9
86 slo-vo
02/2011 OTOTM Winner
86 slo-vo's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: work and play
86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all
Default
order me a set of those 35's for $50 a piece and ill come and get them lol
__________________
FORD....built without your tax dollars.
86 slo-vo is offline   Reply With Quote
Old 04-03-2010, 09:18 PM   #10
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Here are a few pics of how high the front sits. Its about 12" higher than before swap.
This is just the coil sitting in place for the picture. I have changed the caster angle since the picture.
Track bar bracket and modified coil bucket.
Went ahead and fixed the cab mounts.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
