Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Reply
Thread Tools Display Modes
Old 09-07-2010, 10:11 PM   #1
prerunin13
prerunin13's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Sitting in the garage until the noise goes away
prerunin13 is on a distinguished road
Default Squealing/Chirping/Whirring
Hi, I have a 2000 Ford Ranger 3.0 V6. I have a terrible squealing/chirping sound. I have replaced the cam synch and cam sensor, throw out bearing, slave cylinder, motor has been removed and completely gone through with new seals and new bearings. Still makes the same noise.
I have removed the serpentine belt - same noise. I have lubed the daylights out of the cam synch and also put in another one to make sure the new one I bought wasn't faulty out of the box - same noise. Ran it without the tranny hooked up - same noise. Any ideas? I'd hate to have to drive it off a cliff, but the idea is becoming more and more attractive each day.
Thanks!
__________________
Ya a 2WD goes just fine in the dunes, is your quad 4 wheel?
prerunin13 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 09-08-2010, 07:56 AM   #2
srteach
srteach's Avatar
Vehicle Year: 1999, 2001
Vehicle Make: Ranger, F350
Vehicle Model: XLT supercab, SuperDuty
I use this vehicle for: DD / light OR, DD
srteach will become famous soon enoughsrteach will become famous soon enough
Default
That noise usually comes from
Quote:
Originally Posted by mtnrgr View Post
idler pulley or belt tensioner pulley
but you have removed (and I assume, ran without) the serpentine belt.
I have had a squeal caused by a worn out IAC valve before.
Check all the bearings for a sticky spot in the rotation. Check oil pressure (with an actual gauge). Remove or replace thermostat (to test for squeal only).
I don't know if any of these will help find the culprit, but good luck.
srteach is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
