The new 2019 Ford Ranger is powered by the 2.3l EcoBoost engine.
Also check out ‘Ford Ranger 2.3L EcoBoost Engine Introduction‘.
ENGINE 2.3-liter EcoBoost® I-4 with Auto Start-Stop |
Configuration | Aluminum block and head |
Intake manifold | Lightweight composite shell-welded |
Exhaust manifold | High-flow three-port cylinder head with integrated exhaust manifold |
Valvetrain | DOHC, four valves per cylinder, twin independent variable camshaft timing |
Valve diameter/lift | Intake, 31 millimeters/8.31 millimeters; exhaust, 30 millimeters/7.42 millimeters |
Pistons | Lightweight high-strength cast aluminum with low-friction skirt coating and steel ring carriers |
Connecting rods | Forged steel with full floating pins |
Ignition | Distributor-less with coil-on-plug |
Bore x stroke | 3.45 x 3.7 inches (87.5 x 94 millimeters) |
Displacement | 140 cubic inches (2,300 cubic centimeters) |
Compression ratio | 10.0:1 |
Engine control system | Powertrain control module |
Recommended fuel | 87 octane |
Fuel capacity | 18 gallons |
Fuel delivery | Direct injection |
Oil capacity | 6.2 quarts 5W-30 with filter (10,000-mile service interval) |
Power | 270 horsepower |
Torque | 310 lb.-ft. |
