DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities, it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
2019-Present Ford Ranger Tech:
If your looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Ignition:
Duraspark Basics
2.8 Duraspark Conversion
Remote Mount TFI Ignition Module
MSD Ignition On A Ford 3.0
3.0L Camshaft Position Sensor
4.0L Camshaft Synchronizer
3.0L & 4.0L Camshaft Position Sensor
2.8 Round Distributor Rotor Problems
4.0 (SOHC) Plugs & Wires
PATS Programming With Forscan
Ford Chip Key Basics or What Blank Key Should I Buy
Computer:
TFI Diagnostics
EEC-IV (OBD-I) Diagnostics
OBD-I 2-Digit Codes
OBD-I 3-Digit Codes
OBD-II Trouble Codes
Diagnosis Using The O2 Sensor
Throttle Position Sensor (TPS) Operation & Test
Ford Ranger Emission Test Driving Cycle
Ford P1443 & P0401 Trouble Codes
Ford P0155 & P1151 Trouble Codes
Evaporative Purge System Check Engine Code P1443
P1445 Purge Flow Sensor Circuit High Input
PATS (Passive Anti-Theft System)
Understanding The Ford PATS (Passive Anti-Theft System)
Battery & Charging:
Parasitic Draw Battery Test
Charging System Trouble Shooting
Electrical Diagrams
Charging System Information & Checking
Alternators
Dual Battery Setups
Cheap Dual Battery Setup
Automotive Battery Basics
130 Amp Alternator Swap
130 AMP Alternator Install
130 AMP Alternator Upgrade
200 AMP Alternator Upgrade
Fuses:
1983-1992 Fuse Box Diagrams & Checking Fuses
1993-1997 Fuse Box Diagrams & Checking Fuses
1998-2000 Fuse Box Diagrams & Checking Fuses
2001-2003 Fuse Box Diagrams & Checking Fuses
2004-2011 Fuse Box Diagrams & Checking Fuses
