DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Original Version:
This section replaced the old Tech Library of the original website that can still be found HERE. (No new articles added here after 2018)
2019-Present Ford Ranger Tech:
If your looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Wiring Diagrams:
If you’re just looking for wiring diagrams, click HERE.
Off-Road Lighting:
How To Choose An Off-Road Light
Electrical – Lighting:
1983-2011 Ford Ranger Light Bulb Guide
High Beam Upgrades
Rewire Fog Lights For All Light Settings
Fog Light Bulb Upgrade
2007 Fog Light All Light Modification
2007 Turn Signal Modification
Wiring For Trailer Lights
LED Lights For Your Truck
1989-1992 Ford Ranger Headlight Moisture Repair
1993-1997 Taillight Upgrade
Dull Headlight Lens Fix
Yellow Headlight Lens Fix
Polishing Your HeadLights & Taillights
1993-1997 To 2001-2005 Taillight Swap
Swap ’98-’00 or ’06-’11 Taillights on ’93-’97 Ranger
1983-1992 Ford Ranger Third Brake Light Upgrade
Wiring:
Selecting The Proper Wire Size
Ford Electrical Connector Identification
How To Use Relays
Properly Wiring Accessories
On-Board Air:
On Board Air – Options & Reviews
On Board Air From Ford A/C Compressor
Onboard Air From Sanden A/C Air Compressor
On-Board Air From York Compressor
York Compressor Service Manual
1993 Ford Ranger On-Board Air Using A/C Comp
Horns:
Kleinn Train Horns
Short Burst Horn Mod
Ford Ranger Horn Upgrade
Fuses:
1983-1992 Fuse Box Diagrams & Checking Fuses
1993-1997 Fuse Box Diagrams & Checking Fuses
1998-2000 Fuse Box Diagrams & Checking Fuses
2001-2003 Fuse Box Diagrams & Checking Fuses
2004-2011 Fuse Box Diagrams & Checking Fuses
