Choosing A 35-Inch Mud Terrain Tire For Your 4x4
One
of the most important choices you make as a 4x4 owner is your
tires. This page will give you information on the different tires
available, as well as specifications and side by side comparisons. There's
also links to check prices, reviews, and links to the manufacturers.
Hopefully,
this page will better inform you of the tires available.
Looking
for 33-Inch Mud Terrains? Click HERE.
Tread
Designs:
Light
truck tires come in basically (3) designs:
All Season Tire |
All Terrain Tire |
Mud Terrain Tire |
All
Season - The all season tire belongs on cars and 2wd trucks. They're
pretty much a passenger car tire with no off road capability. Keep
walking past those to the better tires.
All
Terrain - Every 4x4 truck or SUV should come with all terrain
tires. An all terrain tire is built with off-road standards, but designed
more for street performance. They'll typically give you slightly better MPG
than a mud terrain, and don't create the noise associated with some mud
tires. They're best suited for snow, and mild off-road conditions such as
dirt roads and mild trails.
Mud
Terrain - If you ever plan to take your truck off-road, this is
the tire you want. In fact, it doesn't even need to be a true off-road
vehicle. Some people use them for traction on the trucks they tow their
off-road vehicles with (because you usually end up having to park it in a
field somewhere), or on farm vehicles that need to drive in to fields. The
aggressive tread and deep voids allow them to get a good bite without
clogging up with mud.
![](../tech_library/tires/mud_terrain_void.JPG)
(The
colored area shows the void in this mud terrain)
In
addition, there are some competition and rock crawling specific tires, but
we're not going to get in to that. If you're in to competition rock
crawling, then you're likely not reading this.
Construction
Designs:
Besides
choosing the type of tread design, there is also Radial and Bias ply
tires.
Bias
Construction Tire |
Radial
Construction Tire
Bias
Ply - Although they're not as plentiful as they
use to be, there are still several bias ply off-road tires out there. Bias
tires typically have the ply cords that extend diagonally from
bead to bead at a range of 30 to 40 degree angles. Each successive
ply is laid at an opposing angle, forming a criss-cross pattern.
This design allows the entire tire body to
flex, as the tread and sidewalls share the same casing plies. The
flex allows for better gripping, better clean out, and conformity
to rough and rocky terrain. Bias type tires are best suited for
extreme off-road conditions where grip, cleanout, and traction are
top priority. These tires are just as strong in the sidewalls as
in the center of the tread. While they may not flex as readily as a
radial, the flex in the tread makes up for it.
Bias tires tend to
wear out quicker and form flat spots compared to their
counterparts. The flexing also means increased rolling resistance,
a noisy tire, and less control and traction at higher speeds. A set of bias ply off-road tires
will usually only last 20,000 - 30,000 miles when used
on the highway.
Radial
- Radial
constructed tires utilize ply cords that extend from bead to bead
at approximately right angles to the centerline of the tire. They
are parallel to each other, and are combined with stabilizer
belts. They have good directional stability offering a smooth ride,
and tend to last for more miles than a bias tire.
Their
drawbacks are weaker sidewalls, and the steel belts hamper the radials
ability to conform to trail obstacles.
Evolving
Technology:
While
bias tires have been considered to have a stronger sidewall than a radial
tire, manufactures have been working to improve the sidewall strength of
their off-road tires.
![](../tech_library/tires/goodyear_tire_kevlar.JPG)
Goodyear
Wrangler MT/R with Kevlar
Goodyear
offers their Wrangler MT/R with a Kevlar reinforced sidewall, and they
claim it helps increase sidewall puncture resistance by 35%. Some
manufacturers also list their off-road tires with a 3-ply sidewall, and
claim that it makes them more puncture resistant.
What's
Available:
Below
is
a chart showing the different 35-inch mud terrains available. The chart
includes:
Tire
dimensions / specifications
Side
by side comparisons
Price
ranges
Links
for checking prices
Reviews
& ratings
Links
to the manufactures page for the tire listed
You'll
notice that most of these tires are not a true 35-inch tire. You'll also see
that some have a deeper tread measurement than others.
Mud Terrains
BFGoodrich Mud Terrain KM2
35x12.50x15 |
Hancook Dynapro MT
35x12.50x15
![](../tech_library/tires/goodyear_wrangler_mtr.JPG)
Goodyear
Wrangler MTR
35x12.50x15
![](../tech_library/tires/kumho_road_venture_mt.JPG)
Kumho Road Venture Mud
Terrain |
35x12.50x15 |
![](../tech_library/tires/dunlop_mud_rover.JPG)
Dunlop
Mud Rover
35x12.50x15
![](../tech_library/tires/mastercraft_courser_mxt.JPG) |
Mastercraft Courser MXT |
35x12.50x15 |
Construction |
Radial |
Radial |
Radial |
Radial |
Radial |
Radial |
Overall
Diameter (in) |
34.8 |
34.8 |
34.8 |
34.7 |
34.8 |
34.72 |
Overall
Width (in) |
12.5 |
12.9 |
12.5 |
13.6 |
12.5 |
12.2 |
Tread
Width (in) |
N/A |
9.8 |
N/A |
N/A |
9.6 |
9.88 |
Approved Rim Width
(in) |
8.5 -
11.0 |
8.5 -
11.0 |
8.5 - 11.0 |
8.5 -
11.0 |
8.5 -
11.0 |
8.5 -
11.0 |
Tread
Depth (in) |
20/32 |
19.5/32 |
21/32 |
20/32 |
20/32 |
20/32 |
Tire
Weight (lbs) |
60.5 |
N/A |
N/A |
67.9 |
53 |
N/A |
Warranty |
Life of
tread or 6-Years |
50,000 /
Prorated |
60,000 Miles |
5-Year /
Prorate |
6 Years /
Free replacement first year or 2/32" of wear, then prorated
until 2/32" |
Undefined |
Price
- Online Dealer |
TireRack.com
Discounttire.com |
TireRack.com |
TireRack.com |
TireRack.com |
Onlinetires.com |
Rating |
N/A
N/A |
Price - Amazon |
Check Price
N/A
Check Price
N/A
N/A |
N/A |
Reviews - Amazon |
Read Reviews![](https://ir-na.amazon-adsystem.com/e/ir?t=therangerstation-20&l=ur2&o=1) |
N/A |
N/A |
N/A |
N/A |
N/A |
Rating
- Amazon |
![](../tech_library/tires/5-star.JPG)
N/A
N/A |
N/A |
N/A |
N/A |
Price - 4Wheelparts |
Check
Price |
N/A
Check
Price |
N/A |
N/A |
N/A |
Reviews - 4Wheelparts |
Read
Reviews |
N/A
Read
Reviews |
N/A |
N/A |
N/A |
Rating 4Wheelparts |
![](../tech_library/tires/4-5_star.PNG)
N/A
![](../tech_library/tires/4-star-4wp.PNG) |
N/A |
N/A |
N/A |
Manufacturer Link |
BFGoodrich |
Hancook
Goodyear |
Kumho |
Dunlop |
Mastercraft |
Mud Terrains
![](../tech_library/tires/procomp_xtreme_mt2.JPG) |
Pro Comp Xtreme MT2 |
35x12.50x15 |
![](../tech_library/tires/dick_cepek_mud_country.JPG)
Dick Cepek Mud
Country |
35x12.50x15 |
![](../tech_library/tires/dick_cepek_crusher.JPG) |
Dick Cepek
Crusher
35x12.50x15
![](../tech_library/tires/nitto_mud_grappler.JPG)
Nitto Mud Grappler
35x14.50x15
![](../tech_library/tires/mickey_thompson_baja_mtz.JPG)
Mickey Thompson Baja MTZ
35x12.50x15
![](../tech_library/tires/mickey_thompson_baja_claw_ttc.JPG)
Mickey Thompson Baja Claw TTC
35x12.50x15
Construction |
Radial |
Radial
Radial |
Radial |
Radial |
Radial |
Overall
Diameter (in) |
34.6 |
34.8
34.8 |
34.80 |
34.8 |
34.8 |
Overall
Width (in) |
12.5 |
12.2
12.2 |
14.57 |
12.2 |
12.2 |
Tread
Width (in) |
N/A |
10
10.0 |
N/A |
10 |
10 |
Approved Rim Width
(in) |
N/A |
8.5 - 11.0
8.5 -
11.0 |
10 - 12 |
8.5 - 11.0 |
8.5 -
11.0 |
Tread
Depth (in) |
20/32 |
29.5/32
29.5/32 |
21/32 |
19.5/32 |
20.5/32 |
Tire
Weight (lbs) |
N/A |
66
66 |
N/A |
66 |
67 |
Warranty |
40,000 Mile Tread Wear Warranty |
Prorated Replacement
60 Months
/ 1st 25% Worn |
Prorated |
Prorated |
Price
- Online Dealer |
Discounttire.com |
TireRack.com
TireRack.com
N/A |
N/A |
SummitRacing.com |
Rating - Online Dealer |
N/A |
N/A
N/A |
N/A |
N/A |
N/A |
Price - Amazon |
Check Price
Check Price
Check Price
Check Price
Check Price
Check Price
Reviews - Amazon |
N/A |
N/A
N/A |
N/A |
Rating - Amazon |
N/A
N/A
![](../tech_library/tires/4-star.JPG) |
N/A |
Check
Price
Check
Price
Check
Price |
Check
Price |
Check
Price
Check
Price
Read
Reviews
Read Reviews
Read
Reviews |
N/A |
Read
Reviews
Read
Reviews
Rating - 4Wheelparts |
N/A |
Manufacturer Link |
Pro
Comp
Dick
Cepek
Dick
Cepek |
Nitto |
Mickey Thompson |
Mickey
Thompson |
Mud Terrains
![](../tech_library/tires/maxxis_buckshot.JPG) |
Maxxis Buckshot |
35x12.50x15 |
![](../tech_library/tires/maxxis_bighorn_mt.JPG) |
Maxxis Big Horn |
35x12.50x15 |
![](../tech_library/tires/toyo_open_country_mt.JPG) |
Toyo Open Country Mud
Terrain |
35x13.50x15 |
![](../tech_library/tires/yokohama_geoloander_mt.JPG) |
Yokohama Geoloander
M/T |
35x12.50x15 |
![](../tech_library/tires/pit_bull_growler.JPG) |
Pit Bull Growler
35x14.50x15
Pitbull Rocker
35x13.50x15
Construction |
Radial
Radial
Radial
Radial |
Bias |
Bias |
Overall
Diameter (in) |
34.6
34.6
34.8 |
34.5 |
35.5 |
35.50 |
Overall
Width (in) |
13.1
13
14.4 |
13 |
15 |
14.92 |
Tread
Width (in) |
N/A
N/A
N/A
9.8 |
11.4 |
12.30 |
Approved Rim Width
(in) |
10
10
8.0 - 11.0
8.5 -
11.0 |
12 |
12 |
Tread
Depth (in) |
21/32
21/32
21/32
19/32 |
22/32 |
22/32 |
Tire
Weight (lbs) |
N/A
N/A
79 |
60.5 |
68 |
73 |
Warranty |
6-Year
6-Year
1-Year / First 25%
5-Year |
5-Year |
5-Year |
Price
- Online Dealer |
Onlinetires.com
Onlinetires.com
N/A
TireRack.com |
ok4wd.com
Price |
ok4wd.com
Price |
N/A
N/A
N/A
N/A |
N/A |
Price - Amazon |
N/A
N/A
Check Price
Check Price
N/A
N/A
Reviews - Amazon |
N/A
N/A
N/A
N/A |
N/A |
N/A |
Rating - Amazon |
N/A
N/A
N/A
N/A |
N/A
N/A
N/A
Check
Price
Check
Price
N/A |
N/A
N/A
N/A
N/A
Read
Reviews
N/A |
N/A
N/A
N/A
N/A
N/A |
N/A
N/A
Manufacturer Link |
Maxxis
Maxxis
Toyo
Yokohama |
Pit
Bull |
Pit
Bull |
Mud Terrains
![](../tech_library/tires/super_swamper_ssr.JPG) |
Super Swamper
SSR |
35x12.50x15 |
![](../tech_library/tires/super_swamper_tsl_bias.JPG) |
Super Swamper TSL (Bias) |
15/35x15
![](../tech_library/tires/super_swamper_tsl_sx.JPG) |
Super Swamper TSL SX |
35x15.50x15
![](../tech_library/tires/super_swamper_bogger.JPG) |
Super Swamper Bogger |
35x14.50x15 |
![](../tech_library/tires/super_swamper_trxus_mt.JPG) |
Super Swamper
TrXus MT |
35x12.50x15 |
Super Swamper LTB |
35x12.50x15 |
Construction |
Radial
Bias
Bias |
Bias |
Radial |
Bias |
Overall
Diameter (in) |
35.3
34.8
34.8 |
35.0 |
34.9 |
35.2 |
Overall
Width (in) |
12.5
14.3
15.4 |
14.4 |
13.0 |
12.1 |
Tread
Width (in) |
10.6
12.5
13.1 |
12.5 |
9.5 |
9.8 |
Approved Rim Width
(in) |
8.5 - 10.0
10
10 - 12 |
10 |
8.5 - 10.0 |
10 |
Tread
Depth (in) |
21/32
25/32
25/32 |
25/32 |
19/32 |
24/32 |
Tire
Weight (lbs) |
77
76
83 |
75 |
69 |
67 |
Warranty |
Unspecified
Unspecified
Unspecified |
Unspecified |
Unspecified |
Unspecified
Price
- Online Dealer |
SummitRacing
Price
SummitRacing
Price
SummitRacing.com |
SummitRacing.com |
SummitRacing.com |
N/A |
N/A
N/A
N/A |
N/A |
N/A |
N/A |
Price - Amazon |
N/A
Check Price
N/A
Check Price
Check Price
N/A |
Reviews - Amazon |
N/A
N/A
N/A |
N/A |
N/A |
N/A |
Rating - Amazon |
N/A
N/A
N/A |
N/A |
N/A |
N/A |
Check
Price
N/A
Check
Price |
Check
Price |
Check
Price |
Check
Price |
Read
Reviews
N/A
Read
Reviews |
Read
Reviews |
Read
Reviews |
Read
Reviews |
N/A
![](../tech_library/tires/4-5_star.PNG) |
![](../tech_library/tires/5-star-4wp.PNG) |
Manufacturer Link |
Interco
Interco
Interco
Interco |
Interco |
Interco |
Mud Terrains
![](../tech_library/tires/maxxis_trepador.JPG)
Maxxis
Trepador |
35x12.50x15 |
![](../tech_library/tires/maxxis_creepy_crawler.JPG) |
Maxxis Creepy
Crawler |
35x12.50x15 |
![](../tech_library/tires/pit_bull_maddog.JPG) |
Pitbull Mad Dog |
35x14.50x15 |
Construction |
Radial
Bias
Bias |
Overall
Diameter (in) |
34.6
34.7
35 |
Overall
Width (in) |
13.1
13.5
15 |
Tread
Width (in) |
N/A
N/A
11.7 |
Approved Rim Width
(in) |
10
10
12 |
Tread
Depth (in) |
21/32
27/32
22/32 |
Tire
Weight (lbs) |
N/A
N/A
72 |
Warranty |
6-Year
6-Year
6-Year |
Price
- Online Dealer |
Onlinetires.com
Onlinetires.com
OK4wd.com |
N/A
N/A
N/A |
Price - Amazon |
N/A
N/A
N/A |
Reviews - Amazon |
N/A
N/A
N/A |
Rating - Amazon |
N/A
N/A
N/A |
Check
Price
Check
Price
N/A |
N/A
N/A
N/A |
N/A
N/A
N/A |
Manufacturer Link |
Maxxis
Maxxis
Pit
Bull |
Shopping
Online & Warranties:
Some
people feel that they need to go to their local tire shop to buy tires.
Sometimes that can limit your options. Some tire shops won't have the
size you want when you walk in, and will have to order it.
Companies
such as Tire Rack have agreements with local tire shops to install tires.
When you buy the tires online, they send them to your local tire shop for
installation. Other companies will charge a flat rate for shipping, or may
offer free shipping.
Amazon and
Discount Tire
usually have tires that ship for free.
Some
people have concerns about their warranty when they order tires online. If
your tire has a manufactures warranty, any dealer that carries that brand
will be able to honor it. Any tire shop will mount tires that you
bring in. Having a shop mount your tires doesn't usually cost that much.
In
this day in age, you have to be an educated consumer and get the best
deal. Even if it means getting tires online with free shipping, or having
them sent to a local tire shop.
Links:
Tire
Rack - 35x12.50x15 Mud Terrains
Discount
Tire - 35x12.50x15 Mud Terrians
