Determine Final Crawl Ratio
This will help you determine your final crawl ratio.
For first (low) gear ratios for manual transmissions click HERE
For first (low) gear ratios for automatic transmissions click HERE
For low gear ratios in transfer cases click HERE.
To determine what your axle gear ratio is click HERE.
  Determining Final Crawl Ratio
Transmission Low Gear Ratio:
Transfer Case Low Gear Ratio:
Axle Gear Ratio:
Crawl
Ratio
New Page 1
© 2019 The Ranger Station. All Rights Reserved 959 Media
